Question about Titan Impact 440 Skid Airless Paint Sprayer
I have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
  • 885 Answers
When you switch it from prime to paint and it's still running:
- If paint/water continues to come out of the prime tube, your prime valve isn't seating properly and needs to be replaced.
- If you get a little pressure at the paint gun but it is surging, your packings, most likely the lower set, are damaged and letting most of the paint leak back past them. Packing/seal kits are available for your machine. Use all parts in the kit and grease/lubricate all of the parts well. Inspect the piston and cylinder for scoring or pitting that can damage new seals. They should be mirror smooth for proper operation and life of the seals.
Posted on Oct 31, 2012
2 Suggested Answers
  • 5 Answers
SOURCE: Titan 440i wont turn on....
Your Transducer is shot the 440i has had this problem since inception. Now they are getting part made elsewhere. Your 440i has a four year warranty. it is covered the part if you dont have warranty cost 85.00 US. It is not a hard thing to replace on your own about 12 min. and your set.
Sincerely Steve Winters
Posted on May 29, 2009
Is there a fuse in th 440i, keeps popping th breaker?
Check the brushes these motors for ever
You could also disconnect the pistion from the motor shaft the connecting rod to make sure the pistion is not the thing that is not moveing and binding the motor .
Most of the time problems come when people don't clean them correctly after use then store then for a few years .
Now I need my pump again except the old paint is now rock hard and nothing moves anymore the lines are cloged filters guns tips check valves .
All I know is my 660 titan witch is the same as the 440 except mine has flat valves instead if balls for check valves has been working great for the last 35 years but I clean it .
Jun 13, 2014 | Titan Air Tools & Compressors
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
440i titan leaking oil
Dis-assemble the gun and wipe everything clean. Light oiling of the air and paint seals is necessary, but someone probably overdid it. Run some thinner through after the cleaning. Good luck!
May 21, 2010 | Air Tools & Compressors
Mar 13, 2009 | Titan Air Tools & Compressors
Titan Impact 440 Skid Airless Paint Sprayer Logo
684 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
