Question about Coleman Electrical Supplies
Titan generator not putting out 220 volts - Coleman Electrical Supplies
mydogisk
  • 50 Answers
SOURCE: No 120 or 220 volts out put on portablegenerator motor runs good.
You should find out which wires are you excitation fields and flash them with a 9volt battery. That should make 120 volts
Posted on Apr 10, 2009
  • 1383 Answers
SOURCE: i get no 110 or 220 volt power
generac was purchased by Briggs Stratton some years ago, however some information is available at the following web address, just enter your model number:
http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm
The small board that you describe is the bridge rectifier that converts ac from the windings to dc for the armature. You can test the brush/board by removing the part from the generator and applying 12 to 16 volts ac to the input tabs/wires then test/read dc (dc voltage will be lower than input ) voltage at the brushes. Use meter to make sure that you are getting dc. I use a small power supply less than one amp that I purchased at the thrift store for a couple of dollars. If test fails replace part. If it tests ok re-install brushes and re-connect the ac power supply to brush/board which in turn will energize the armature. At this point test the armatrue for magnetic power. I use a thin welding rod or wire against armature. If you feel a magnet start the engine. If the windings are good you should get some voltage at the plugs and the two wires that feed the brushes (will not be full voltage). If voltage is present, kill engine and disconnect ac power supply and connect the original wires to brushes/board and start engine. If you now have voltage at plugs you spiked the system indirectly by energising the armature. If still no voltage you may have an open circuit that feeds the brushes or diode pack is failing with the incresased voltage. Good luck with your repair and email if you have questions.
Posted on Apr 14, 2009
protek480
  • 1714 Answers
SOURCE: generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
Posted on Jun 26, 2009
cj2176
  • 520 Answers
SOURCE: coleman generator not putting out enough volts
What can happen with these generators is there is a shield built into them to devert the heat that is produced but it is still released into the surrounding components and causes a plastic rain guard to melt slightly around the edges and the melted plastic fuses to the armature and causes voltage drop through the brushes due to lack of contact. It is a relatively simple fix but it requires a rebuild kit that can be purchased aftermarket through your local generator dealer. It provides instructions for the rebuild but are often times confusing and it is usually cheaper in the long run and less hassel to let the dealer install the rebuild kit for you. If you do decide to attempt this yourself there is an 800 number provided where it can be registered and it will allow you to access schematics online for this rebuild. Hope this helps, good luck!
Posted on Sep 02, 2009
blown725
  • 15 Answers
SOURCE: titan 7000 generator...the generator is not
you know , i have helped several people on thire cars , i want a fix and you want money...not faiir at all....i thought this sight was a helpful sight...i see diferently now....thanks
Posted on Sep 03, 2009
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Have inherited a homelite generator- LR5000T what grade of oil does it take. Also, does it support 220 volt equipment? Equipment draws less than 15 Amps.
Yes, this generator supports 220 volt. The grade of oil advertised for this generator is 10W30, 4-cycle.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | Homelite Garden
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
After installing my titan N100 the breaker keeps tripping went from 50 amp breaker to 60 and still keeps tripping how do Isolve this problem?
You had an instant heater there before? Or a different type? Your breaker numbers don't mean anything to me, I need amps and volts, what is the amp? 30? and the volt is 220? Or are you in Europe?. And you had the four wires in there before? And you have all 4 wires on the heater line? And the heater is grounded? It should work. Unless it is not getting enough juice, but you already upped the amp. Let me know what you got.
Jul 03, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Coleman powermate 4000 pops circuit breaker on the 220 side.
Don't know what you mean by "on the 220 side".
The generator has two joined circuit breakers that each are 110 volts. Between the two is 220.
If just one of those is opening WITH NOTHING PLUGGED IN, then there are only a few explanations.
1. There is a short in the wiring or the wiring has been tampered with and connected incorrectely.
2. The switch that switches the mode from 120 to 240 has gone bad, possibly with a welded contact. This would occur if the switch is changed with load on the generator. This could put a driect short on half the generator winding and cause one of the breakers to blow.
3. Worst is a winding short in the generator. Fortunately this is the least likely.
4. The 220 receptacle has been broken and insulation failed shorting one terminal to another.
Nov 14, 2009 | Coleman Powermate Premium Plus 6250W...
I want to make my 110 volt generator into 220 volt
most generators have a 220 volt plug on them from the factory, if it is a small one it might not have the capabilities of 220. If it has the 220 plug then you will just need to wire the proper 220 male end onto whatever you are trying to run.
Oct 25, 2009 | 2003 Yamaha YZ 125
Titan 7000 generator...the generator is not
Sep 02, 2009 | Electrical Supplies
220 volt outlet
you can find it in electrical store.
Jul 05, 2009 | Electrical Supplies
Apr 09, 2009 | Electrical Supplies
Run ac off of generator.
you need to use a volt meter and test which lead from the 4 wire output of the generator a 220 v is coming out.
the round center prong of the ac is its ground and should not be connected to any live power. it could be left unused.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Hampton Bay HBLG5004 Air Conditioner
Electrical Supplies Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
