EMACHINE HAVE AN UNMOUNTABLE BOOT VOLUME. HOW CAN I FIX THIS PROBLEM?
  • Computers & ... Master
  • 27,725 Answers
Run hard drive diagnostics: http://www.tacktech.com/display.cfm?ttid=287 (or http://www.bleepingcomputer.com/forums/topic28744.html)
Make sure, you select tool, which is appropriate for the brand of your hard drive.
Depending on the program, itll create bootable floppy, or bootable CD.
If downloaded file is of .iso type, use ImgBurn: http://www.imgburn.com/ to burn .iso file to a CD (select "Write image file to disc" option), and make the CD bootable.
You could also try a Live Linux like Knoppix Live from here:- http://www.knoppix.net/get.php,
download the Free ISO using a Torrent, burn it to a CD then run that it will load into Ram and then ith all the software in the CD you can examine the hard drive
hope this helps
Posted on Oct 29, 2012
  • 5 Answers
SOURCE: unmountable boot volume
it sounds like the drive has been locked by another system.if this is posible,you would have to unlock it using the original system and its utilitys.you could also have it unlocked by your local computer service dept. D-Dan
Posted on Aug 25, 2007
Geekman
  • 32281 Answers
SOURCE: averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Posted on Nov 23, 2008
ohms
  • 1879 Answers
SOURCE: Unmountable boot volume
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Posted on Jan 11, 2009
shakeelm
  • 224 Answers
SOURCE: HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Posted on Mar 07, 2009
SOURCE: blue screen unmountable boot volume
1. Go into the bios by tapping the F12 during initial start up
2. Under the system configuration tap select SATA Operation
3. Then Change the selection from AHCI to ATA
This may render you hard drive temporally inaccessible which means you will have to reinstall the operating system.
Posted on Apr 28, 2009
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
chkdsk /r
Mar 07, 2009 | Dell Latitude D600 Notebook
Jan 11, 2009 | HP Compaq nx7010 Notebook
Averatec 3280 unmountable boot volume
Nov 22, 2008 | Averatec 3200 Notebook
Unmountable Boot Volume
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
