Question about Dryers
Conversion kit bought used stove set to lp need to know what i need to hook up to natural gas
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the make and model number?
Posted on Oct 28, 2012
  • 184 Answers
SOURCE: converting my kenmore elite dryer from Natural gas to LP
MOST KITS HAVE AN INSTRUCTION SHEET WITH THEM.
USUALLY, THE ONLY THING YOU WILL HAVE TO DO IS REPLACE THE VENT CAP ON THE REGULATOR WITH A BLOCKING PIN AND REPLACE THE ORPHICE ON THE VALVE. BE SURE YOU CHECK FOR GAS LEAKS AFTER REASSEMBLY. BE CAREFUL NOT TO COME INTO CONTACT WITH THE IGNITOR. IT IS ON THE END OF THE BURNER.
IT DOES NOT BEND AT ALL. IF YOU PUT TOO MUCH PRESSURE ON IT, IT WILL BREAK.
Posted on Apr 08, 2008
rickzilla
  • 706 Answers
SOURCE: Dryer won't heat
Hello tfulton1963,
The fact that it worked for 3 days and then failed suggests that it is probably something else. You may have a non-resttable thermal fuse that opened or the gas valve itself isn't functioning. Can you see the glow of the igniter when it starts? Are you sure the burner is getting gas from the inlet valve?
These are the basic components to investigate.. Let me know the outcome of these checks and we can get you going again if none of these work.. Regards
Posted on Oct 11, 2008
SOURCE: I need access to gas valve in my Maytag mdg5500aww dryer
When I posted the question, I had not removed the front of the dryer. I thought the gas burner etc. had to be accessed from the back. As soon as I removed the front of the dryer I realized it was all up front and accessable. Conversion was straight forward from that point.
Posted on Jan 17, 2009
  • 130 Answers
SOURCE: Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Posted on Jan 26, 2009
  • 10 Answers
SOURCE: Convert Maytag Dryer to LP from Natural Gas?
yes it is very much necessary. the natural gas pressure is much lower that LP. it is @3.5 in, water column. The monometer is a pressure reading instrument that will tell what pressure is present at the gas source, appliance gas manifold and gas valve. Read the conversion kit instructions well. And adjust pressure according to data plate specifications. A u-tube water monometer is the best and most accurate however a standard analog will surfice. Please use caution.
Posted on Mar 07, 2009
Need help on converting my jenn air from natural gas to Lp! the location of the new orifice's and what size goes where??? I bought a conversion kit from AppliancePartsPros! Stove Is a Jenn air jdr8895aas
give the kit to the gas fitter that you will get in for the job
gas conversions are not a DIY job as it is not just the jets but the positioning of the air shrouds for correct burn
Jul 19, 2017 | Jenn Air Kitchen Ranges
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
Want to convert from natural gas to lp propane
A conversion usually consist of new burner(s)/nozzle(s)/orrifice(s) and either a new regulator/gas valve..
Some gas cook stoves or ranges come with the ability to run on either fuel and the spare nozzle or orrifice will be attached somewhere on the stove.. usually under the range top.. the gas valve may have a small lever that you simply move to the preferred fuel setting.. NAT or LP.
The appliance must have a rating plate that states it can be converted.. and if so..typically a conversion kit will be available or may have been included in the appliance package.
LP Gas runs at a higher pressure.. making a broad statement here.. converting from Natural to LP is more dangerous if the proper steps are not followed then converting from LP to Natural.. which typically just results in a weak flame.. regardless. it's still dangerous.
Many modern appliances will have a warning label stating it can only be used with a certain type of fuel. Heed the warning.
If your appliance did not ship with the alternate fuel kit or has a warning label.. do not attempt to convert it.. it will be much safer and cheaper to buy the proper appliance.
Best of luck.. and be careful
Mar 29, 2011 | Heating & Cooling
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
I have a 48" GE Monogram 4 burner with griddle gas/ duel fuel range (ZDP48N4GD1SS) that was set up for natural gas. I need to convert it to LP but the parts website doesn't show a conversion kit for this...
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Aug 19, 2010 | GE Monogram ZDP48N4GHSS Stainless Steel...
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Whirlpool regulator
Hello arizonascrat
Welcome
You said You just bought a whirlpool gas stove, but it is set up for natural gas and you need it to be for propane gas. How do you do this? Do you have to purchase anything, if so where? Whirlpool GR 465 LXLS THANKS, in advance, Norma
They make an LP conversion kit What you are asking and it should cost only about $20 dollars.
One Model # is, 8576846A
Now some places have it using different numbers!
Make sure to ask if this is for you range. I believe on kit fits all Whirlpool Gas products.
We have sponsors here on fixya that you can order this from.
One I believe is the repair clinic.
Thank You for using Fixya.
Huuum
Please remember to leave me a solved rating!
Oct 12, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Dryers Logo
24 people viewed this question
Top Dryers Experts
