Question about Belkin (F6C800-UNV-PL) UPS System
I am not geting no power and site wiring fault stay on how can i fix that problem
I am not geting no power and light site wiring fault stay on
  • fimber Oct 28, 2012
    i am not geting no power and light site wiring fault stay on
Battery light stays on and drains battery. Brand new battery, alternator and starter?
What is year--make--model?
If something wrong with wiring circuit, somewhere, replacing the part won't fix it.
Make sure charging system is working properly. To look up wiring diagram, I need vehicle info. The battery lite is on even with key out? Unplug alternator, see if light stays on, check the alternator wiring connector.
Mar 06, 2016 | Cars & Trucks
How to fix impala engine code p2070?
code p2070 refers to intake manifold air control actuator--actuator stuck open or refers to intake manifold air control solenoid --solenoid stuck open=== causes ---wiring---intake manifold air control actuator---mechanical fault OR---wiring---intake manifold air control solenoid---mechanical fault.
Mar 01, 2015 | 2006 Chevrolet Chevrolet Impala LT
Blue power on LED stays on, won't shut off, no picture, power or sound.
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Jul 31, 2014 | Olevia Televison & Video
Hot Surfacelight stays on. How do I fix it please.
First Shut the power off to the Range at circuit breaker! If THAT TOP IS STILL ON?! Your range is Haunted! You have a fault in the circuitry which is usually called a Dead Ground. Meaning there is a ground wire that is frayed and touching bare metal. This is keeping the circuit open or On. The Other is you have a faulty knob that turns the element on/off. The knob (switch) can be tested but is Very Involved~! I would replace your switch that controls the surface element staying hot. Usually (cause we use them more) it is the front two and one of them is worn out (just like people get). IF, you still have an issue your going to have to trace the Black wire back with a Lighted Probe you can get at Auto Zone/Pep Boys for $5. This handy tool will light up if you have the Range completely off at circuit breaker and you start at the element and work towards the switch (knob). If any part lights up and it is properly grounded. There is your fault or open frayed wire needs replacing. Good Luck!
Jun 28, 2014 | GE JBP66 Electric Kitchen Range
Dynostic reading shows 6 faulty solenoids
log on to kiausa.com
Very good site with guided fault seeking and all info you need.
See the wiring diagram there what is common for all solenoids --> ground or 12v +
Mar 25, 2014 | 2006 Kia Cerato 2.0
42"philips plasma 7 red blinking light.
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
This is the fault indication meant by 7 blinks of standby light. Just visit this site 'Electro-help' Faults with plasma TVs are described in detail. Check this link and select the site. Pull up older posts there.
Jul 18, 2012 | Philips Televison & Video
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
ABS light stays on
have you had abs system checked with a scan tool?if you cannot communicate with abs module with a scanner,there is main power feed circuit that corrodes under fuse block underhood..also have seen corroded wires near abs module over top of transmission..if you have communication..you may have a speed sensor fault..if a front sensor,check wiring behind splash shields in fenderwells,if rear sensor fault,most likely sensor is defective..also check for water intrusion into rear wheel bearings by removing sensor from hub unit
Apr 16, 2009 | 2006 Dodge Caravan
Belkin (F6C800-UNV-PL) UPS System Logo
52 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
