Question about Honda Em1600x, 1800x, 2200x, Eb2200x Generator Parts Catalog
Auto throttle not working on eb 2200x - Honda Em1600x, 1800x, 2200x, Eb2200x Generator Parts Catalog
My EB2200X generator won't generate electricity
Check output on diode pack on the back of genny maybe stuck or brushes need replacing.
Oct 15, 2014 | Honda Em1600x, 1800x, 2200x, Eb2200x...
My Honda EB3500X Shuts off when auto throttle is switched on making me run full throttle at all times. Cause? Solution?
if your engine shutting down, then your auto throttle is working.
when you hit the switch watch the throttle arm move on the carburetor to the idle position,if so you may have to clean the carburetor jet and fuel nozzle ports.possibly this occurs when unit has been stored for quite some time.once jets are cleaned it should maintain idle.
May 31, 2014 | Honda Eb 3500 Generator
Whare is the points on honda gen 2200x
it wont have any it will be electronic ignition
Sep 28, 2013 | Honda 3000 Watt Portable Generator
I have starview box and its losing stations slowly has anyone got same problem or a solution.i live in dublin south (for ntl)
When my box does this I just re-scan it..that normally works...press menu then factory setting type in 0000 then go to installation and auto re-scan (will take several mins) when done make sure the emu key is on. and you should have all your channels back.
Good luck
Gord
Ps if you need them the NTL codes are
00=B0 B8 4F 04 E6 5F 87 80
01=A3 EB EC 07 D6 49 D2 EB
To input the codes press menu then key in 1570 this will bring up another menu..enter nagravision to input the codes.
Mar 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Hi i need a code for the euovox max. im in dublin
5a 01
00 aa b7 d1 d9 ce 8e 83 af
01 a3 eb ec 07 d6 49 d2 eb
Jan 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need codes for ntl eurovox dublin ireland
Codes working on 08/06/2009
5401
b0 b8 4f 04 e6 5f 87 80
a3 eb ec 07 d6 49 d2 eb ...
Dec 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes Dec 18th
NTL DUBLIN THURSDAY 18TH DECEMBER 00 Code - B0 B8 4F 04 E6 5F 87 80 01 Code - A3 EB EC 07 D6 49 D2 EB Have fun ****
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Need eurovox codes for ntl ireland please
  • For starview super box
  • Press MENU
  • Press 1570
  • Go to NAGRAVISION and press OK
  • Go to Key Number with the arrows on your remote, press two times to the right. Now you should have 00 again
  • Go Key Data and enter this code: B0 B8 4F 04 E6 5F 87 80 and press OK.
  • Go back to Key Number and press arrow to change to 01
  • Than go back to Key Data and enter code: A3 EB EC 07 06 49 D2 EB and press OK.
  • Last step: press EXIT 3 times. Your channels should be now restored.
  • Ps. Make sure to install all numbers and letters of the code don’t over look any of them for this will cause problems reinstalling your channels…. try wit eurovox
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Honda Em1600x, 1800x, 2200x, Eb2200x Generator Parts Catalog Logo
104 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
