Question about Sylvania Hdtv And Dvd Player Combo 32 Inch Flat Lcd Hdmi Ld320ss2 Parts Repair
Sylvania hdmi tv is shutting off when i go to turn it on.
When i turn it on. it shuts off. i have to keep hitting the power button until it turns back on. can you please tell me whats wrong with it?
  • 24 Answers
This person on FixYa had a similar problem.
Posted on Oct 28, 2012
Color problem on tv
The TV remote control can recovery your color as you want
Jun 08, 2012 | Sylvania LD320SSX LCD TV
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
I need the three digit code for the ge universal remote control for sylvania 6513DD please.
Hi, You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Nov 06, 2010 | Sylvania 6513DD 13 in. TV/DVD Combo
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
I lost my one for all codes sheet need help please i have a sylvania tv
press and release the tv button , then press and hold down the set button . the light will blink twice ,now enter code991 ,light will blink twice again. now aim remote at tv and keep pressing tv and power buttons untill your tv shuts off. now try to turn tv on
Oct 11, 2009 | Universal Remote Control Remote Control
Problems w/ Sharp LC-46SB54U remote programming
i will help with the easiest way, hit the TV button, then hold the setup button untill the light blinks twice, then hit 991, it will flash again, hit the 1 again, then hit power, then hit the chanel up button, and if it dont shut off, hit the chanul up button again, keep going this every 2 seconds(with the chanel up button) untill the power shuts off, when it shuts off, hit the setup button again, that will lock it in, hit the power button again-TV should come back on, if that dont work, use the volum up button , after doing the first few steps, hope this helps
Jan 10, 2009 | Sharp LC46SB54U 46 in. LCD TV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV Turns off on its own
Just keep smack'in it around, it works for me. It is the 'protection overload circuit' taking over and shutting the TV set off. This is because it detected a short or near-short circuit somewhere. Most common is high voltage, deflection amplifiers and main power supply. It's pretty much a common fix for an experienced tv repairman. It might set me back in the ballpark of $200 - $300.
Jul 03, 2007 | Sylvania SRT4127P TV
Sylvania Hdtv And Dvd Player Combo 32 Inch Flat Lcd Hdmi Ld320ss2 Parts Repair Logo
132 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
