Question about Samsung LN32A330 32 in. LCD TV
No Signal or Check Signal cable?
I have just plugged my ps3 into my sumsung 42in plasma with av and says as above also tried hdmi no go please help
  • atgentle Jan 05, 2009
    Thanks heaps for that some how i went out and my flatmate had a fiddle and it started to work shes not sure how but maybe she gave it a wiggle like you said once again thankx
    Sergeant:
    Champion:
  • 247 Answers
Did you make sure tv was on the right channel or on the right line (1, 2, or3,) channel? if ao, how old is the ps3? try wiggling the cable in the back of the ps3. it might get the signal to come through. if it that works then the prot on the ps3 is bad. find out if it is still on warantty.
Posted on Jan 03, 2009
  • Thomas Jan 05, 2009
    will you please rate this for me.
    thanks
    tom
I'm trying to plug my ps-3 to my panasonic viera th-50pz80u with an AV multi-out but i have no signal. No sounds, no images. Please help me
In your PS3 configuration you'll likely have to set the PS3 so that it is using the multi-AV rather than HDMI.(In Video Output Settings) Also on the TV input you'll have to select composite in rather than HDMI.
https://support.us.playstation.com/app/answers/detail/a_id/788
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Hope this helps,
Jeff
Nov 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Nothing show up on tv screen after plugging in the cables. the HDMI and the AV cables too.
Hi, try the following
1 using the av lead and not the hdmi so plug the av lead into your tv and make sure your tv is on the correct input
2 turn the ps3 on at the back
3 now press and hold the on button down until the ps3 switches itself back off
4 then press the on button again, doing this resets the video mode from hd back to standard av so once you have done this you should have a picture on the tv, if not check your on the correct input
if you have done the above and it still dont give you any video than please let me know then ill do my best to assist you further ok
please rate this solution, thanks
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
When playing regular dvdson my ps3, the screen will sometimes go black for just a second or two then come back on. I sometimes notice a red or green flash of color right before the pic goes out or comes...
Ok I have had this happen a few times before. What I do to fix it is disconnect the HDMI cable while everything is still on and playing and then re-insert the cable back into the TV. This re-configures the HDMI signal and should hopefully stop this problem.
Hope this helps and thank you for using FixYa
Aug 31, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Sound keeps cutting out momentarily on ps3 connected to samsung plasma tv via hdmi cable
Make sure game disk is clean and scratch free. Try and hook up the video with original AV cables (Red,Wht,Ywl) and unplug HDMI.Try another HDMI cable. If none of these help you could have bigger problems. Good Luck.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Samsung LN32A330 32 in. LCD TV Logo
226 people viewed this question
Henry  Thomas
Henry Thomas
