Question about Hilti Drills
Hilti te56 hammer stopped working and red light flashing
Stopped working
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Replace motor brush
Posted on Nov 21, 2012
  • 61 Answers
SOURCE: hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Posted on Oct 11, 2009
  • 61 Answers
SOURCE: Hi, My hammer drill HILTI TE76-ATC has service red
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Testimonial: "Thanks"
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 61 Answers
SOURCE: I have a Hilti TE 905 AVR the service light came
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Posted on Dec 13, 2009
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
IT WILL NOT COME ON
Please check the the manual on page 15
https://www.us.hilti.com/medias/sys_master/documents/h29/9077506998302/PUB_5135115_000_APC_RAW.pdf
Oct 10, 2014 | Hilti TE 70 Hammer Drill Performance...
Why did my hilti te 805 just stoped working when drilling can anyone help
A real Hilti brand means it has got the operating hours on it.
Only service a complete kit of components , this machines are have most liquid oil lubrication (most of the times a very expensive) Turmopol oil and special poor tolerance bearings HILTI and DUSS are high quality machines , Duss machines i prefer some higher then Hilti because of the long last service for more then 40 years old machines they have all te parts for them , but not cheap Unfortunately.
If a hammer stopped working like Dewalt all the parts are simple to get. most of the times a broken powercable or a brush that have become in protected state autostop , Dewalt hammer in the States is not the QS quality of Europe i know . but quality like the old ELU machines instead of black and Decker ,
Nice machines and are not fast leak , but it could also after a long period.
Jul 14, 2014 | Dewalt D25330K 2KG Sds Plus Demolition...
I have hilti te 56 has stopped working n red lite show indication spaner please give right solution
Hilti has sensors in their tools to detect when things are wrong with them that will shut the tool down under certain conditions. The most common is when the brushes wear down to a point where the tool is shut down so you don't do damage to the expensive armature. Hilti is very stingy with the information on how to reset the system even if you install new brushes, they want you to send the tool to them for repairs or reconditioning. They do a great job, very quickly and you'll essentially have a new tool but it can be expensive so if you want to go this route call to see what the service will cost or if they'll tell you what's wrong, sell you the parts needed and tell you how to reset the sensors.
Aug 31, 2012 | Dewalt D25330K 2KG Sds Plus Demolition...
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
I've just brought a Hilti te56 atc, not to sure of
No way. Are you not getting the variable speed to work? Sounds like the electronics control is bad.
Mar 27, 2012 | Drills
I have a TE 74 and it has just stopped hammering, the motor still runs ok but no hammer action, any suggestions?
could be quite a few things. e.g. stuck ram worn o rings and seals. I would suggest calling Hilti direct at 1-800-879-8000 for a service center nearest you. These are not the most user friendly tools to repair. It can be done but trust me it is a pain.
Feb 16, 2012 | Hilti Drills
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
421 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
