If it is the result of blown head gaskets, you will need to remove the intake manifold, since you will need to remove it any way to replace the head gaskets, while you have the intake off just pour the water out. then you may want to blow the moisture out with compressed air hope this helps
Whatever you do, do NOT continue driving it this way until it is fixed. Hydraulic lockup can bend a piston rod ot even detonate the engne. I think it got so hot at one point that it blew a head gasket. Have a qualified mechanic perform a cooling system Pressure check. If it holds pressure, which I doubt, it may be antifreeze running into your cylinders from he intake manifold. But the pressure test should tell you which head gasket it is, but have BOTH replaced, since they both underwent the stress.AND while replacing those gaskets, a new intake gasket will be installed too, as a matter of course. The price is about the same, since they have the top of the engine apart anyway. Just for information: White "smoke" is vaporized coolant or water being pushed out the tailpipe from the engine. Blue "Smoke" is oil, and Black "smoke" is soot- too much unburned fuel.
Valve covers leaking oil OUT the tail pipe, no way in hell! Valve covers can leak oil onto the exhaust manifold, but there is no way its going to get into the exhaust from there and out the tail pipe.
Bad valve guides and/or valve guide seals would put oil from the top of the head and into the cylinders. That is a far bigger job than just replacing valve cover gaskets.
Don't let the warranty company give you any more of that kind of BS.
On the 3.1L engine you have to remove the push rods to replace the intake manifold gasket. It is possible that you didn't tighten down one rocker arm, or you have it mis-aligned.
usually a sign of a blown head gasket or intake gasket or, gulp a cracked head or block. Check your engine oil for a milky color, This would confirm a blown head gasket. There is a test to determine if hydrocarbons are in your coolant. If your coolant level is low or empty, this is another sign.
Make sure you use OEM Injectors. The white smoke might come at a 3.5 from a bad gasket bewteen the intake manifold and the throttle boy or if you have the 3.8 from bad gaskets between the intake manifold and the engine.
