Question about Hobart Undercounter Dishwasher, Hot Water Sanitation, Fresh Water Rinse, Delime Notification-LXIH-4
We bought a used LXi hobart dishwasher , it leaks water around door, is there supposed to be a gasket around door
  • 68 Answers
SOURCE: Where do I get a lower door gasket for a Hobart SR24C dishwasher?
If I'm not mistaken, there is no lower door gasket. Typically, DW doors don't seal. Due to the temp of the water, when you load a rack a burst of cold air is also loaded in the machine. The DW starts a cycle and cause the air to warm and expand. The doors will always gurgle during a cycle.
The key to reducing this is to make sure the level of the unit it proper. Slightly higher in front. The front lower channel should guide the water back into the unit. Also, don't leave the door open unless you're removing or starting a rack. The warmer the cavity stays, the less the air will expand.
Posted on Apr 25, 2008
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
whytfang
  • 170 Answers
SOURCE: Leaks water from bottom of door. Error code E7 ?
I found this and it also may have to do with the door seals...how old is the unit...if door seals get old and stiff..(not soft and pliable) they sometimes leak...after usage the heat and moisture may cause them to swell and or become soft thereby sealing better...but this is what I found in the user manual.
Machine displays "E7" on LX30 model or "CLEAN PROBE" on LX40 model.
1. Clean water sensors inside tank.
It suggests contacting Hobart if this fails but I also found this problem is associated with fill issues...as in an E4 error...this what you do in that case....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Good Luck and I hope this helps...let me know if it doesn't and i am sure I can get to the bottom of it...thanks for rating my effort...the Fang.
Posted on May 19, 2009
traboH
  • 27 Answers
SOURCE: Hobart dishwasher leaking as it rinses/fills
If the brand is Watts, a rebuild kit is available from Hobart. Their part # 118270. It should contain the float with a red rubber gasket and a bonnet o-ring. Unscrew the cap, clean off the sealing surface and drop in the new float OR you might find a local Watts distributor and see if they carry the kit. That should solve the leaking issue. Let me know.
Posted on Nov 01, 2009
  • 110 Answers
SOURCE: Hobart LXI Dishwasher a P3 code is flashing, seems
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Posted on Mar 16, 2010
Hi I have a Hobart LXIH dishwasher and it is leaking water out of the bottom corners of the door. Do you know what might be causing this?It has a seal at the top but no seal on the sides or bottom.
Make sure your rinse wash arms have the end plugs. If one is missing, water will spray out door.
Your fill valve could possibly be malfunctioning, therefore not closing all of the way. I used to work for Hobart. These LX machines can be a pain in the rear. If you have a water softner, then the valve is probably functioning normally. I do not recall it ever being the door gaskets. I would think you should be getting an error code with the wrench. This is a hot water machine. If you have lime scale building up inside, you may try deliming it. The drain valve could be also causing a problem. There are so many things it could be.
Oct 16, 2017 | Hobart Dishwashers
Hobart sr24c is leaking water out the bottom of the door during operation.
You have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainage
Apr 21, 2016 | Hobart Dishwashers
Hobart LXI-H rinse doesn't work
water flow pressure needs to be a min. of 15 PSI..
Apr 26, 2012 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Water leak
Check the gasket seating. It should be uniform.
Hope the correct dimension gasket is used!
May 25, 2010 | Dishwashers
Leaking from under the door. replaced the gasket around the door but it is still leaking from the door
i found this website repairclinic.com and found the "foam seal" part of the door that is supposed to stop the water from leaking out. I also went to partselect.com and got a diagram of the door whick also told me that I maybe get door seal (btm).
Nov 24, 2009 | Maytag Dishwashers
OFF-ON procedure.
5. Delime machine.
May 19, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Oct 14, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart Undercounter Dishwasher, Hot Water Sanitation, Fresh Water Rinse, Delime Notification-LXIH-4 Logo
705 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
