Question about Casablanca Fan 3245T Ceiling
Casablanca ceiling fan with W-11 W-12 control; which toggle direction, left or right, is Piwer On?
  • 3 Answers
SOURCE: Fan turned on by phantom signal
Have had similar problem for years when main power supply is interrupted for even a few minutes (lightening storm, brief outage of some sort). When the power supply returns, the fan starts up at the highest speed - not great when you aren't at home. (Mine is in an older kitchen with old time gas pilot lights in the range.) I replaced the wallswitch control - but I still turn off the main power switch when I know I won't be at home
Posted on Jun 28, 2008
  • 70 Answers
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Posted on Sep 01, 2010
Where can I find a replacement for the Glass?
Casablanca sells parts. Go on-line to locate the part number you need from a schematic and either order directly from them or through a certified dealer. No worries!
Apr 10, 2015 | Casablanca Fan Hampshire C7M62M Ceiling...
How can I change from a remote control system ( which rarely works) to a wall control switch for my isotope 44 from casablanca
Casablanca may be able to supply instructions for alternate methods of wiring your fan for direct control vs. remote control.
Jul 28, 2014 | Casablanca Fans 44" Casablanca Isotope...
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
Just bought the house- it has a casablanca del mar but no remote- the wall switch does not work- can i override the remote?
usually remote control for ceiling fans does not have an override code like the ones available for control using a universal remote. because they are specifically designed to work with certain IR or Radio frequency signals.
Usually a replacement remote is available but you may have to contact the manufacturer to check for availability.
Here's Casablanca Support phone number:
Call Toll Free: 1-888-227-2178
Hope this helps!
Aug 03, 2011 | Casablanca Fan 3845Z Ceiling Fan
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
My inteli-touch casablanca fan won't turn on at all (light or fan). Today there was an interruption of electrical power to the house and now the fan won't work. I know there is a way to "reset"...
I have had 3 casablanca intellitouch fans stop working. All 3 had the same problem. The 1000uf/35vdc capacitor failed. Replaced with 1000uf/50VDC cap from Radio Shack. No problems since.
Nov 09, 2010 | Casablanca Fan 3245T Ceiling
I HAVE A CEILING FAN CONTROLED BY A HARD WIRE EMERSON WALL SWITCH. THERE IS NO SWITCH ON THE FAN TO CONTROL CHANGING DIRECTIONS OF THE FAN. DOES THE SWITCH CONTROL FAN DIRECTION AND IF SO HOW DO YOU CHANGE...
I have a Casablanca fan with a similar controller. In order to change direction on my fan I have to press the FAN and POWER buttons at the same time. I imagine they are not that different, so you might want to give it a try.
Sep 14, 2010 | Emerson (33416-78414) Fan
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Aug 07, 2008 | Casablanca Fan Televison & Video
Jul 16, 2008 | Casablanca Fan 3245T Ceiling
Casablanca Fan 3245T Ceiling Logo
235 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
