Question about HP LaserJet 3050 All-In-One Printer
No paper pickup
I have hp laser 1050.
first paper is jam inthe printer.i give tha 6 pages print ,the 5 th page of paper is jam ,iam remove the cartiage and remove that jammed paper.and coming 6th page print.ok, next i will give print that disply is "NO PAPER PICKUP".
the paper is not take and not print
plz give me answer.
damodar
anantapur
9291253141
    Novelist:
  • 125 Answers
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Posted on Jan 09, 2009
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
HP Laser Jet 4250, print getting very light in last few months or year. 135K page count, 6 years old, 600 DPI, PCL 5 - Windows Vista HP Cartridge, or compatible cartridge no difference - still light No...
The laser mirror could be dirty, the transfer roller could need changing. Looking at the "print quality" sub menu, the toner density default setting is 3. Up it to 4 or 5. See if that makes a difference. Remove the cartridge and open the covers. Use canned air or an air compressor and blow out the printer.
Sep 01, 2011 | HP Office Equipment & Supplies
When I try to print a page, printer does not pick up paper and then gives error message that printer is out of paper when there is plenty of paper in the tray. Sometimes if the printer hasn't been...
Hello.
From the HP site:
There could a problem in the pickup assembly area of the product. There are twoblack Mylar light shields approximately 3.5 inches long. They are located onboth sides of the pickup roller under the pickup roller rod. One or both ofthese black Mylar shields can be tucked under, or partially bent when removinga paper jam from the paper input tray slot.
Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity until the fingertips reach the end of the cavity.
4. Bend fingers up to push theblack Mylar light shields back into place. The proper position of the blackMylar light shield will be flat.
5. Reconnect the power cord.
6. Print a self-test/configuration page to verify product is functioningcorrectly.
If still a problem, make sure that the tray, paper is locked in thecorrect position. Sometimes the spring in the tray can become worn out andloose. You can take that out and spread it out a little. Also, make sure thatthe tray bottom is free to move. Take out the paper and see if it goes up anddown correctly. If you don't hear the pickup roller moving or the motor runningyou may have a bad feed roller gear. There also, could be a problem with thepickup roller.
Hope this helps.
May 23, 2011 | HP PSC 2355 All-In-One InkJet Printer
There is a paper jam...how do I unjam it
Hi dorothyhover,
Here's how you would clear paper jam from your Brother HL 1430:
1. Remove the paper cassette completely from the printer.
2.
Pull any jammed paper up and out of the printer.
3.
Open the front cover and remove the drum unit assembly.
4. Pull any jammed paper up and out of the printer.
Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
6. Close the rear cover and install drum unit assembly, close the front cover.
Hope it helps.
Thank you for using Fixya.
Apr 28, 2011 | Brother HL 1430 Laser Printer
I have a Brother 5370DWT. I replaced the drum about 5 weeks ago and just yesterday I started having jamming issues. Every couple of pages the printer is jamming. I have to pull a page from the drum and...
I have had the same problem on these machines, try cleaning the paper pickup rollers, ive also found that some remanufactured cartridges causes this problem, I dont know how or why but they do.
Dec 09, 2010 | Brother HL-5370DWT Laser Printer
13.20 but no paper jammed in path hp9500n ( col laser jet not mfp 9500..).. c8546a.printer boots and immediately gives 13.20 remove paper jam. cleaning page passes through ok when doors are closed...
Open tray 4 and the right
side door to check for
jammed media. Check the paper path
between tray 4 and the
printer. Check the tray-size
guides. Replace the pickup,
separation, or feed
rollers. ur problem 100% resolved
Feb 09, 2010 | HP LaserJet 9500n Printer
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
HP LaserJet 3050 All-In-One Printer Logo
179 people viewed this question
Ben Johnson
