Question about Hayward 1.5hp Max Flo Inground Pool Pump # Sp2810x15
NEED REPAIR MANUAL FOR SP2810X15 HAYWARD POOL PUMP. HOW DO I REMOVE THE MOTOR FOR THE EMPELLER/
  • 11 Answers
SOURCE: noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Posted on Feb 17, 2009
john224
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
protek480
  • 1714 Answers
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Posted on Jul 03, 2009
  • 106 Answers
SOURCE: How dose the empeller come off a Hayward Pool
It unscrews. Remove back cover, hold shaft and spin impeller off.
Posted on Jan 16, 2010
Testimonial: "Thanks"
  • 366 Answers
SOURCE: 1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Posted on Feb 22, 2010
Testimonial: "Great. Thanks for the quick feedback. I look forward to saving a few $'s this year operating my pool. Cheers!"
Pool pump squealing
sometimes the gasket from the wet side of the pump fail and the pool water enters the bearing assembly of the pump. if there is a descent pump store, they can change the bearings within an hour. otherwise, a new pump is the solution
May 31, 2014 | Hayward 1.5hp Max Flo Inground Pool Pump #...
The capacitor is burned and i think thas the problem why the pumps doest'n star
Is there power to the pump or is a breaker being tripped? Find out where, exactly, the power is out. It could be loose wiring in the conduit or a loose connection where it wires into the motor. Many things.
www.cpo2go.com
Dec 02, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Pressure at about 10psi then drops to zero then back then drops to zero again. Sputter flow of water. Filters and filter baskets have been cleaned.
Try replacing or lubricating the seal on the basket lid. Pool pumps rely on a completely sealed system to work properly. If there is any air getting into the system on the suction side the pump will surge.
Oct 16, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Start pool up this year pump is louder makng whine noise, works fine and it is not getting hot Is the pump going
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
May 22, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Accidentally sprayed water to my swimming pool 1.5hp pentair motor while it was running, There was a loud noise and the breaker tripped off. After more than 24 hours tried to turn it back on but continues...
Thank you for posting your question here on Fixya.com.
Apparently you grounded the motor and that likely blew the winding hence the reason it still trips the breaker. You could megger it or use a multimeter to confirm but in the end the solution will still be to take it to a local electric motor repair shop to see if it can be salvaged or a replacement motor is needed. The motor brand new is about $207. For a formal quote on the motor please forward all your motor nameplate information to me using the contact feature found at www.arrowmotor.net or www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 06, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
How dose the empeller come off a Hayward Pool Pump?
Jan 16, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
When installing a pump, does it need to be bolted to the pad? Aren't most pads today styrofoam?
No they do not. It may vibrate and run with some noise if it is not tight to the ground but other than perhaps being annoying, the noise wont hurt anything.
Aug 09, 2009 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Hayward 1.5hp Max Flo Inground Pool Pump # Sp2810x15 Logo
65 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
