Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Briggs & Stratton 5550 generator won't start
Generac workhorse 5550, ran this morning for about thirty minutes with new gas, would not start this afternoon, changed spark plug, cleaned filter, checked oil, pressed reset button,
  • butchpend
    butchpend Oct 28, 2012
    I tried the wd-40 not luck...I took the fuel line loose and I have fuel coming out of the line where it joins the carb.
  • butchpend
    Took the plug out and grounded it, no spark...could a new plug be bad?
4 Suggested Answers
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
ROMOAS
  • 97 Answers
SOURCE: Genarac Briggs and Stratton Engine Family
http://www.partstree.com/parts/
hope this helps
Posted on Aug 30, 2010
SOURCE: generator is burning oil and choking out
Bad Gas Mixer....if Two Cycle.....Burning Gas/Oil mix if Four Cycle.....Got The Gas Cans Mixed Up Dude...or Dudess
Posted on Nov 11, 2011
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
Generator won't start
model# 1971 starts on first pull runs about 3 minutes and cuts off
Jun 30, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Looking for a replacement battery for a Generac protable generator #01470. Users manual calls out part number 193043GS Generac does not recognize this #, at least onlnie.
Try that number through a Briggs and Stratton parts dealer. Your generator is now owned by Briggs and Stratton Power Products division.
Feb 17, 2011 | Garden
I have a 5550 generator and all the sudden the power outlets stopped working. I pressed the reset buttons and nothing. I hooked my electrical device to another generator and it works. What is the problem...
Hello, it sounds like either you have a voltage regulator failure, the rotating field coil is shorted or opened, or the exciter windings have failed. No easy answer because there are a number of issues here as you can see. Depending on how old the unit is you might have warranty. I would suggest you take it to a generac service center to have it checked out. I have 30 years experience with generac units. If it is a voltage regulator issue, (this can be expensive) you can get a jobber regulator. This link is for a good generic substitute. http://www.mcphersoncontrols.com/html/mcp_products/voltage_regulators/MTS63-4.html
I have used this regulator on 4000 watt to 50 kw units successfully. If it is a winding, then to rewind the stator part of the generator is expensive and a new generator is cheaper.
joe
Jan 15, 2011 | Briggs & Stratton Briggs Stratton 6200...
Troy bilt 5550 generator no start please help
May 25, 2010 | Briggs & Stratton Power Products 5,550...
I have a 5550 Watts Briggs & Stratton that only ran since purchase for 2 hours tops The pull starter locked up when I tried to start engine.
unscrew the four bolts holding it on and chek the rope has not become tangled dont unscrew the centre bolt as the recoil spring will suddenly shoot out everywhere
Mar 20, 2010 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
313 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
