Question about Brother Office Equipment & Supplies
Brother MFC-J825DW All-in-One Inkjet Printer
My printer do not print the red color
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Posted on Jun 05, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
  • 903 Answers
SOURCE: Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
Posted on Jun 04, 2010
Brother mfc-j825dw, Service manual
For a service manual, contact Brother directly.
Mar 27, 2017 | Brother "MFC-J825DW Wireless All-in-One...
How do I set printer to make a two sided print?
Find the dialogue for 'duplex' printing and check the box.
Mar 03, 2015 | Brother Mfc-J825dw Multifunction Printer
How to select printer in brother control center 4
Hi Ron,
Go To Below official Brother Printer Page For Your problem, Configure or change the settings of the ControlCenter 2 or Brother Still having Problem Then follow Us For Brother Printer Support
Feb 14, 2014 | Brother Office Equipment & Supplies
BLACK WONT PRINT ON BROTHER MFC-J825DW
Needs more Cleaning on Black (3 times) then leave the machine ON but dont do anything on it. There is Negative pressure and it needs 1 day to go away
Jan 31, 2014 | Brother Mfc-J825dw Multifunction Printer
Brother MFC-J825DW false paper jam error
In my case that was registration actuator leaning to the side.
I was able to find it by removing back cover, and gently moving black plastic actuator to the side (stick).
It's prety well described in Brother "SERVICE UPDATE No. F1400" that I googled.
Good luck
Feb 22, 2013 | Brother MFC-J825DW Wireless All-in-One...
Mfc-j825dw keeps saying scanner cover is open and its not. how do i fix this
short of returning it for another look to see if the lever where the cover closes is not got tape or something preventing it from seeing the door is shut.
Aug 27, 2012 | Brother MFC-J825DW Wireless All-in-One...
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-240C
you might try a head cleaning and re calibration exercise first.
May 25, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-620CN Printer
my brother mfc-620cn printer is printing backwards if you had a see threw paper itnwould look right
Jan 26, 2007 | Brother MFC-620CN All-In-One InkJet...
976 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
