Question about Whirlpool WED6200S Dryer
I think need to change the wire cord, but don't know if it's going to work properly
Need to change 4-wire cord to 3-wire
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Take a look at this video.
Posted on Oct 28, 2012
SOURCE: I need to change the
I did no know this was a subscription service when I started. I will not need your service any further.
Posted on Jul 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpoo dryer change from 3 prong to 4 prong cord
The following link explains how to convert an applaince from a 3-prong power cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope you find this information helpful and that it clarifies any questions you may have. If you still require assistance, please let me know.
Posted on Oct 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: Changing electrical Cord from a 3 prong to a 4
Your 4 wire cord has red...black...white...and green wires.
On the dryer terminal block,put the white wire on the center terminal.
The green wire goes outside the terminal cover to the nearest screw for grounding.
The black and red wires go to the outside terminals on the terminal block. It does not matter which is right or left.
Posted on Dec 20, 2009
  • 351 Answers
SOURCE: how do i hook up the electrical cord properly?
Posted on May 08, 2010
lancaster5
  • 245 Answers
SOURCE: need to change cord from 4 wire to 3 wire
All you have to do is make sure the middle wire on the strand of three goes to the middle screw the other two just go to either side. Your ground screw just gets tightened down without a wire. I do this everyday.
Posted on Aug 21, 2010
Changed motor car wont charge found 4 broken wires in harness 2 in ground repared them still wont charge was told pcm needs to be replaced and programmed. what about pigtail on alternator being bad
Yes, repair the alternator wire. The pcm does not control alternator output, it only uses and monitors it. I don't know if it is a problem, but maybe from the bad wiring you found may have affected it. Don't know who told you to replace the pcm, but think I'd get a second...well, a third opinion.
Sorry I can't help you more, good luck.
Nov 06, 2012 | Cars & Trucks
Need wiring digram
Some units the cord is actually detachable, if you don't think this one is, contact your manufacturer to see if they offer a replacement cord that you can purchase. Some do, some don't.
Sep 06, 2012 | Frigidaire FAC127S1A Air Conditioner
Need duralast inverter remote switch
good luck, i dont even think they make one. just get a phone cord plug it in and see which two wires make it turn on. touch them momentarily to see..........you know what i'll just do it and report back
Jul 16, 2012 | Electronics - Others
My skull candy ink'd left bud broke apart,how to re-wire it.
The wires inside the cord have broken, Unfortunately there is really no easy way to fix it, they don't solder well and replacing the cord is the only option but this also may not be successful. Replacing the headphones is the only proper solution
Mar 01, 2012 | Skull Candy Audio Players & Recorders
My sound not working on my headphones so how do I fix it ?
By constantly bending the cable back and forth at the same place, you've created fatigue in the cable and caused one or more of the small individual wires inside it to break. The only way to get the headphones to work again is to access the wires just above and below the point of the break. You'll need to have enough of the wire to strip the insulation, solder them together and then insulate with tape or heat shrink tubing. Unfortunately, the resulting repair will not look very pretty, but will work and should work for a long time with proper care. if you can make this repair inside the headphone then the ugly looking splice / solder can be kept out of view and not be subjected to pull strains.
Since you didn't include the brand and model - I don't know which type headphones you have. You may have better luck simply replacing the entire cord, or shortening the existing cord to the point of the break and installing a new plug at that point. If it is too short, you can buy an extension cord for the headphones. This will be the best looking solution, and will work nicely - as long as you don't pull too ******* it - causing the plug to pull out of the jack.
Please rate my reply & good luck!
Now you know not to do that anymore..
Jan 21, 2012 | Audio Players & Recorders
Need user manual huawei m615
i dont think user manual is provided extra...
otherwise please comment below and rate my answer 5star ..telll me your problem or anything you wanna know about it and i'll help
Dec 01, 2011 | Cell Phones
I need to change from a 4 prong to a 3 prong but I am confused about the bonding strap.........do I need this?
Hello, my name is mike. If you are changing the 4 prong to a 3 prong , no you don't need the bonding strap. Yes it is nice to have. All it does is help secure it, However, if you want just wrap some electical wire around where wire goes through plate to help protect any vibration on the cord. As long as wires are good and tight, and secure your good to go, Mike.
If you ever want to talk to me in future and directly to me, here is my link to my page on fixya.
http://beta.fixya.com/users/mc1bean
Sep 20, 2011 | Roper Dryers
I need to change powercord from a g & e electric dryer.it ends into like a square black block,going inside dryer.
It depends on what type of cord you are changing to. I think what you're describing as a sqaure black block is the terminal block.
If your new cord has four wires, should be black, white, red, and green. If this is the case, it goes like this:
Black to the far left screw (L2)
White to the middle screw (N)
Red to the far right (L1)
Green goes to the cabinet, usually behind a green screw.
If this is the case, you're changing from a 3 wire cord to a 4 wire cord, and your 3 wire cord is still connected; then behind the middle screw is probably a strap connected underneath it. When you change to the 4 wire cord, bend and push the strap up out of the way for future use if needed. It acts as the ground for the 3 wire cord.
With the 4 wire cord, the green mounted to the cabinet acts as the ground.
Now......
If i'm wrong with the above, and you're intalling a 3 wire cord; they could all be the same color (the wires). If so, just put....
The far left wire to the far left screw.
The middle wire to the middle screw with the strap attached to it.
the far right wire to the far right screw.
I hope this is helpful, and that I havent completely misunderstood you and wasted your time. I would be glad to help any further if you need it.
Thanks,
Mike
Jul 26, 2011 | Dryers
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
NEED TO KNOW HOW TO HOOK UP A 4 PRONG CORD TO DRYER WHAT COLOR GOES WHERE
The following link explains how to properly connect a 4-prong power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this helpful.
Oct 07, 2010 | Kenmore Dryers
Whirlpool WED6200S Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
