Question about John Deere 3010 4010 Pto Shaft 540
John deere 4010 pto stuck - John Deere 3010 4010 Pto Shaft 540
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a John Deere travelling sprinkler model
You can go to the following:
http://www.gilmour.com
There is an 800 number to call and you can also obtain a manual by selecting "Watering/hose end"
select "sprinklers" then "traveling". There you can download an Owners manual that has a parts breakdown in it
Posted on Nov 03, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
4300 John Deere tractor PTO stuck ingaged won't start Checked linkige help
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
May 16, 2017 | John Deere Garden
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
JOhn deere 214ws baler- need to replace the bolt in the end of powershaft spline on baler end
Been long time. I think its a shear bolt. Should drive straght out. Put same grade bolt or shear bolt back in.
Jul 11, 2016 | John Deere Garden
8130 John Deere pto code 1883.01
Rear PTO Underspeed. Make sure correct shaft is installed. Restart vehicle and select proper PTO engagement rate in the CommandCenter. If code returns, have your John Deere dealer repair as soon as possible.
OMAR259982 8130 8230 8330 8430 and 8530 Tractors Block File OURX935...
Last website shows to me what appears to be a sensor just to the right of the icon A pointer, identifying the snap ring, in the top right photo. http://manuals.deere.com/omview/OMAR259982_19/gif/RW55322A.gif
Best of luck.
Dec 16, 2015 | John Deere Garden
3010 gas tractor idles fine , but spits and sputters when a load is placed on it . what could cause this ?
bad carb got dirt in it do carb rebuild on it also look for water in gas ingas before you do it i would clean tank and fuel filter to
Sep 04, 2014 | John Deere 3010 4010 Pto Shaft 540
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
I have a John Deere L-130 and the electric PTO appears to be engaged even when the switch is turned off and the wiring to the PTO is disconnected. I can start the engine (with the wiring disconnected) and...
Good diagnostic work, uncleparroth! By removing power to the PTO, you've proven that the PTO clutch has stuck/frozen mechanically. If you are mechanically inclined, you can remove the PTO clutch assembly and disassemble it. You could luck out, find something as simple as a broken spring and save a lot of money. Nothing to lose but your time. On the other hand it might not be repairable and you'll have to 'spring' (sorry for the pun) for a new PTO clutch which will cost about $200. Good luck!
Aug 08, 2010 | John Deere Garden
John Deere 3010 4010 Pto Shaft 540 Logo
79 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
