Question about Roper Refrigerators
Roper refrige ice maker quit - Roper Refrigerators
    Top Expert:
  • Roper Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Oct 28, 2012
fridgetech
  • 473 Answers
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Posted on Oct 18, 2007
SOURCE: roper ice maker
My ice maker was making ice just two days ago after being off for a while. I am a new tenant. I made one basket full of ice, which I dumped to make sure the system and water was flushed thoroughly. Now the ice is just stuck there, you can see the cubes but they aren't going anyway. I try to gently force them out, but no way, they aren't budging! So, how do I eliminate this problem?
Posted on Oct 06, 2008
Sea Breeze
  • 4654 Answers
SOURCE: We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Posted on Aug 20, 2009
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
woodchuck789
  • 4066 Answers
SOURCE: no water going into ice maker on our roper side by side refrig
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Jan 05, 2010
Testimonial: "The solution gave something to try. Thanks"
Samsung refrig model rf26xaebp stopped making ice but i still bet water thru the door
The solonoid valve for the ice maker may be faulty or the icemaker may be froze up. Try thawing out the icemaker with a hair dryer. If thats doesn't fix the problem you may have to replace the soloniod or ice maker control. Be sure the arm above thre the ice bin is in the down position. Hope this helps.
Dec 30, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Ice maker quits working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
poptypty
May 23, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker quit working. bar is in down position.
heatman101
nmmnmnbncb
Apr 02, 2010 | Roper RS25AEXLQ Side by Side Refrigerator
No water going into ice maker on our roper side by side refrig
Jan 05, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker wont make ice
Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
Aug 12, 2009 | Roper Refrigerators
Ice maker on G E refrigator
If you have low water pressure to the ice maker it can cause the unit to stick. If the water fill is ok then the ice maker is going out or the freezer is not staying cold enough. Icemaker has to reach about 12 degrees to cycle.
Apr 24, 2008 | Refrigerators
Side by side roper refrig
On most you can gently,slowly and carefully pry the cover off to expose the screws underneath.
Jan 22, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Icemaker does not work
check the water hose. water supply to ice maker
Sep 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
