Question about Maytag MBF 2256 Bottom Freezer Refrigerator
Refrigerator is warm Feezer is extremly cold ice cream too hard
Frost in the freezer
SOURCE: Warm fridge, cold freezer
I had the same problem. There was tons of ice build-up in the freezer back wall which prevented the cold air from flowing into the refrigerator section. I removed all the products from the freezer, and melted the ice - even took off the back panel (lots of ice back there). It solved the problem.
Posted on Feb 19, 2009
  • 291 Answers
SOURCE: Maytag freezer & refrigerator not coold enough
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. I feel heat/warmth on the front edge of my refrigerator....why?
Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
clean the condenser coils as a dirty condenser can make the tubing hotter than normal
- check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
- If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
Posted on Apr 03, 2009
  • 103 Answers
SOURCE: my ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
Posted on Jun 01, 2009
  • 82 Answers
SOURCE: Refrigerator is warm, but freezer works. Coils are frozen.
you are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Posted on Jun 16, 2009
SOURCE: Whirlpool ED5VHGXMB10 side by side
WATER FILTER CHANGED WATER NOT COMING BUT ICE IS COMING
Posted on Aug 01, 2009
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
First my refrigerator side stopped getting cold ,now my freezer isnt working the best , also theres frost in my freezer
you found frost in the freezer on the back wall . this caused no air flow through the coil. what has hapened is / the defrost system has failed . and the ref side gets to warm and next the ice cream will melt . look for bad heater or defrost terminator . and the defrost timer . . most compn problem .. mm
Jul 04, 2010 | Whirlpool ED2FHSS Side by Side...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Feezer does not make ice. there is cold water. Installed new filter
Check the temp inside the freezer with a thermometer. It should be between -10 and 0 degrees. The ice maker has a thermostat that cuts it off once the temp gets above 5 to 8 degrees. (According to the model) If your freezer is warm, check the inside back panel of the freezer. If it has ice or frost on it you have a defrost problem. This will have to be repaired before the ice maker will work. If you have ice or frost, your freezer will also continue to warm up until your fresh food section gets real warm.
Please rate solution
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag MBF 2256 Bottom Freezer Refrigerator Logo
52 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
