Question about Performance Teknique ICBM-32D
Why does it display parking brake on my dvd in dash player
My jensen in dash dvd player keep asking for parking brake sequence
there's a wire from the dvd player that is supposed to be hooked up to your parking brake switch to keep you from viewing during driving. i have a pioneer unit and i ran the parking brake wire to a switch and ran another wire from the switch to ground. then when it asks for the parking brake sequence, (with my unit) i flip the switch from off to on then off then back on. this makes the dvd player think that you've applied, let go of, then applied the parking brake.
Feb 16, 2010 | Car Audio & Video
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Installed a dvd player but i can't get it to play dvds
On the parking brake under the dash is a switch at the top that actuates the parking brake light. On most vehicles most are two wire switches, but some are one wire switches. If you have a two wire switch then you can unplug it and use a test light with the ignition turned on without starting the vehicle and test the wires to see which is the hot wire and then connect to the one that has no voltage on it because it is the ground for the switch. The wire is used to detect the parking brake position as engaged before it will allow viewing of the DVD player when the vehicle is not moving. When the brake is off the DVD player will not play DVDs, this is a safety measure so the driver will not be distracted while driving. Good Luck, RAC
Apr 20, 2009 | 2003 Chevrolet Trailblazer Ext
Car in dash cd/dvd player
Most in car dvd players require a connection to the parking brake so it will not play a dvd while you are driving (in dash only). The easiest way around it is to run a 12v wire to the lead of the parking brake wire on the dvd player. With a constant 12v it should play when the ignition is in the on position.
Sep 16, 2008 | Phase Linear UDV9010 Car DVD Player
Dvd player
ground the wire to metal
Jun 17, 2008 | Dual XDVD8181 Car Video Player
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
My in dash tv dont play dvd when the park brake is on
Sounds like it was wired backwards. The car in-dash receivers with video are suppose to be wired so that they will only play when the parking brake is on.
You should check your manual with your in-dash and find out how the parking brake sense wire is suppose to be wired, typically people just wire them with a switch to ground or +12V (CHECK MANUAL FOR WHICH ONE) and then flip the switch when they want it to play video; or they just wire it permanently to whatever is needed, but on some receivers that won't work because it checks for that.
Mar 18, 2008 | Televison & Video
Parking Brake Wire
I have not a solution but a remedy. If you would like to be able to watch movies while driving, follow these simple instructions. Take out the dvd player, Get one simple toggle switch, install somewhere easily accesible. Now run the parking brake wire from the dvd player to one of the prongs on the switch. Now find a good solid metal ground under the dash, (mounting brace,etc.). Run a wire from this ground to the other prong on the switch. Now reinstall the dvd player, turn on, when blue screen appears, flick the switch, hold for 5 seconds, then flick it back, in a few seconds it should go to the normal screen.
Feb 19, 2008 | Jensen VM9410 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
In dash dvd player
ground out your parking brake wire,,,,,should do tthe job!
Dec 09, 2007 | Legacy LDVD35 Car DVD Player
Performance Teknique ICBM-32D Logo
24 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
