Question about Ovens
Simpson cosmos oven thermostat isn't working and elements won't turn down
dniro592006
  • 121 Answers
SOURCE: Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Posted on Jun 12, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
  • 77 Answers
SOURCE: Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Posted on Nov 28, 2009
  • 3 Answers
SOURCE: simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Posted on Feb 22, 2010
  • 327 Answers
SOURCE: Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Posted on May 26, 2010
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
I took the door off my Simpson Evolution oven and now it won't go back on. Help
you have to push the hinge down and lock it you will need a screwdriver and turn the round disc the one will the slot in this will hold the hinge down do this both sides of the door and put the door back resting into the oven and then turn the slotted discs and that should do the job
Apr 21, 2012 | Smeg Evolution SCP171X Dual Oven
My GE built-in oven is not heating up right away. The oven and broiler elements do not get red hot even if turned up to 500 and/or broil. As a guess it doesn't exceed 300 degrees. This is only...
It could indeed be the elements that are the problem if the elements are bad generally you will see a section of it that looks different than the rest(kinda looks like textured stucco if bad) if that isn't the case the elements must be tested to see if the proper power is going to them, you could do that by TURNING OFF POWER AT THE CIRCUIT BREAKER unscrew the element from the back wall of oven and pull element out about 6 inches out, attach a voltage meter set to measure at least 240 volts ac to the two wires, turn on breaker set oven to back and check for 240 vac to element. If 240 vac at element replace element if 240 vac not present the thermostat,or selector switch is bad not providing the 240 vac to element
Good luck,i hope this helps
Gene
Jul 31, 2011 | GE Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
The oven wont get hot, it will warm up and the broiler seems to get hot??
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, you will have to test the element for resistance across the 2 ends , with the meter set on the 200 scale if you get a good reading like 000 it would indicate that the part may be ok but if yoiu get a reading of a 01 or a 1 or lomething like this it would indicate tha part is bad then you need to replace it
However you will also want to
First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem. It won't broil
Apr 11, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Simpson Evolution 904 Wall Oven. The grill doesn't always work
It sounds like you may have a faulty switch. Write down the appliance name and model number. Using your computer go to repairclinic.com you will be able to search for your switch. They are very reasonable on prices and give fast delivery. Hope this helps.
Nov 08, 2017 | Ovens
Jun 12, 2009 | Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
Aug 19, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
