Question about Prestige Remote Start
Audiovox Prestige remote start starts car, but then turns it off after about 3 secs. Does not happen with key start.
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
jpk528
  • 95 Answers
SOURCE: prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Posted on Feb 16, 2009
reynosaelect
  • 165 Answers
SOURCE: I don't know how to use my keyless remote start
DO YOU THE MODEL OF THE ALARM,PROBABLY NOT,EMAIL ME I THINK I CAN HELP YOU,I NEED TO KNOW HOW THE REMOTE TRANSMITER LOOKS LIKE.HERES MY EMAIL: reynosalectronics@live.com.mx
Posted on Mar 17, 2009
  • 87 Answers
SOURCE: My audiovox dealer installed remote starter starts
It dosent sound like there is a transponder bypass installed or installed correctlt, I dont know the year make and model of car but that sounds like what it would be
Posted on Jun 04, 2009
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
How to reset Audiovox Prestige 103bp to work normally
this is a question NOT a solution ........103bp will turn engine over but it is like turning the key quickly and letting it go, it seems the remote starter is not turning engine over long enough to start. Any answers? Onece the car is warm and running or I start it up every 3 hrs , it will start, but if i wait till next day, it will not start the truck
Sep 21, 2013 | Audiovox Prestige 103bp Aps25c Remote...
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
2002 Lincoln Towncar, Audiovox asp901, customer lost her keys and had new ones cut and reprogrammed. Now the remote start will not work. The pats light flashes and it wont start with the remote. I need to...
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Sep 15, 2010 | Audiovox APS901 Car Prestige Remote Start
I have a Prestige Model APS-55TW remote start, when i hit the remote start the car sounds like it wants to start but not turning over? the car will start by turning the key what could be the issue?
try putting the key in the ignition and turn it to on (dont start) try using remote start button if it works you may need a anti theft module or spair ign. key.
Jan 15, 2010 | APS787 Prestige Remote Start and Security...
Cant remember how to use the remote
To start the vehicle, press and release the Key/Trunk button two times within 2 seconds.
Jan 15, 2010 | Prestige Remote Start
I need to know how to set up a key fob for Audiovox PRO-OE2C4S
TURN KEY ON
THEN PRESS VALET SWITCH 3 TIMES
THEN PRESS LOCK BUTTON.
TURN KEY OFF
Jan 04, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Dec 24, 2009 | Prestige Remote Start
Do these work with pus button ignitio
Yes, the remote start can still operate your car, but I suggest not installing it yourself.. Take it to a reputable shop in your area! Push button start cars are different than regular key ignitions, so if you have no experience with remote starts, dont try it.
Dec 11, 2008 | Prestige Remote Start
Prestige Remote Start Logo
55 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
