Question about Honda 1996 Accord
CHECKENGIEN LIGHT ON HONDA ACCORD1996 - Honda 1996 Accord
  • 512 Answers
Go to Autozone and have them test it to see why. Replace whatever is bad and if that doesn't fix it. Post the new problem to CARS and TRUCKS as this is the inverter section.
Posted on Nov 06, 2012
Turn off abs light
Turning off the abs light is not easy to do even if you dissconned the battery the most comeon proble on a abs light to come on proble be n abs sensor each wheel has on you need to put it on a scanner autozone does it for free good luck hope this was helpful good luck
Oct 02, 2015 | Honda Silverwing 600 ABS Motorcycles
Have a 2002 Honda CBR 900 RR the red light between the blinker signal on cluster stays on but run normal what is the red light
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/articles-honda-fireblade/100273-2000-cbr929rr-fi-light-red-light-please-help.html
red light on the dash CBR Forum Enthusiast forums for Honda CBR Owners
Honda Motorcycles Fault Codes Motorcycle Manuals PDF
Honda CBR900RR Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR900RR FIRE BLADE Owner Manual
Feb 24, 2015 | 1999 Honda CBR 900 RR Fireblade
2002 Honda VF 750 C Magna brake and running lights not working
Hi, Rredondo64 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rear Running Light Problems
rredondo64 Honda 2002 Magna with no Brake light or running lights 2002...
Honda Magna VF750C Service Manual
Honda 1995 VF750C Magna Owner Manual
Jun 16, 2014 | 2002 Honda VF 750 C Magna
2006 Honda CBR 125 R change a rear brake light
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2006 Honda CBR125R Brake Light Bulb
Honda CBF 125 Rear Light Replacement
Honda CBR125R Owner Manual
Honda CBR125RW Owner Manual
Mar 16, 2014 | 2006 Honda CBR 125 R
Neutral light on 1992 honda nighthawk
Hi, Anonymous and the usual suspects are:
1. Neutral light bulb burnt out.
2. Faulty neutral switch.
3. A loose bulb in the socket.
4. Faulty wiring from the neutral switch to the light.
5. Grounded neutral light circuit.
Neutral light stays on all the time
93 250 nighthawk neutral light not working
Honda CB750 Owner Manual
Honda CB750F2 Service Manual
Mar 16, 2013 | 1992 Honda CB 750 Nighthawk
HOW DO YOU REPLACE THE TAIL LIGHTS ON A HONDA GOLDWING
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Problem removing tail lights GL1800
How to install LED brake tail lights on Honda GL1800 Goldwing
Honda GL1500 Service Manual
Honda GOLDWING GL1500 Owner Manual
Nov 14, 2012 | 1988 Honda GL 1500 Gold Wing
2002 Honda VT 1100 C2 Shadow Sabre temperature light on
Hi, Glenn if your water temperature light comes on or flickers and the engine does not seem to be overheating the usual suspects are:
1. Faulty temperature sensor.
2. Loose light bulb wire in the instrument harness.
3. Chaffed or pinched wire in the bulb circuit making contact with a power wire.
Overheating Temp light issue
Honda Shadow ACE temp light on
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jul 05, 2012 | 2002 Honda VT 1100 C2 Shadow Sabre
1986 Honda VT 500 C Shadow tail light not working
Hi, Anonymous tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
1984 VT500C Tail light problem
84 vt500c no tail light or license plate light
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Feb 07, 2012 | 1986 Honda VT 500 C Shadow
What is the dash light srs, in a honda accord 2002 vtec engine 3.0
The SRS, or supplemental restraint system, on your Hondamag-glass_10x10.gif Accord 2002,
Read more: How to Reset a Honda Accord SRS Light | eHow.com http://www.ehow.com/how_6403892_reset-honda-accord-srs-light.html#ixzz0tQdveFZn
responsible for deploying the airbag in the event of an accident. If this system is malfunctioning, the airbag may not deploy properly during an accident. However, the system does warn you of a system malfunction. The yellow "SRS" light on the dash will light up, indicating a problem with the system. Once you've fixed the problem, you need to know how to reset the SRS light on your Accord
Read more: How to Reset a Honda Accord SRS Light | eHow.com http://www.ehow.com/how_6403892_reset-honda-accord-srs-light.html#ixzz0tQdgZ0ic
Jul 12, 2010 | 2002 Honda Accord
98 honda accord panel lights will not turn on
Did you check the dimmer to switch? This is for a 2000 Honda Accord but this may help you: If your instrument lights have burnt out on your 2000 Honda Accord.... You may have another problem!!! While the dealer fixes this recall, they should replace your burnt out bulbs. 2000 Honda Accord Recall ID from NHTSA: 04V256000 Auto Recall Date: 06/07/2004 Vehicle Component: INTERIOR LIGHTING Estimated Vehicles Affected: 19572 2000 Honda Accord Defect Summary: ON CERTAIN PASSENGER VEHICLES, THE DIMMER CONTROL FOR THE INSTRUMENT PANEL LIGHTS COULD FAIL DUE TO HEAT BUILDUP. Defect Consequence: IF THIS OCCURS, THE INSTRUMENT LIGHTS MAY FAIL AND, AT NIGHT, THE DRIVER MAY NOT BE ABLE TO SEE THE INSTRUMENT PANEL GAUGES, SUCH AS THE SPEEDOMETER. Remedy: DEALERS WILL REPLACE A MULTIPLEX CONTROL UNIT FOR THE INSTRUMENT PANEL LIGHTS. OWNER NOTIFICATION BEGAN JUNE 16, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009. Notes: AMERICAN HONDA MOTOR CO., P36
Nov 25, 2008 | 1997 Honda Odyssey
Honda 1996 Accord Logo
37 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
