Question about Zyxel Prestige 334W Wireless Router (WYP334WZYXEL)
Problem setting up my netgear WGR614v9
I just got virgin media broadband and i got the netgear WGR614v9 but i didnt get a netwrok adapter, during the set-up it asks you to choose wired or wireless connection and when i pick wired (which is all set up perfectly) it doest let me proceed. the ethernet cable is connected because i looked in network connections. thanks for any help.
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 30, 2009
I have just bought a netgear push2 tv 3000, it shows up as connected to the tv but no way can I get a wireless connection from my Del Vostro desktop PC intel core i5 using windows 7 home premium with...
Go through the installation guide to see the proper setup proceedure.
Then go through the user guide.
http://support.netgear.com/product/PTV3000#wrapper
Always read the manual, they contain helpful information that can save you a lot of headache.
Oct 20, 2013 | NetGear Push2TV TV Adapter for Intel...
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
Unresponsive wireless broadband virgin media
please login to your browser via 192.168.1.1 and change the wireless channel to either 1 or 11.
also if your wifi encryption is set to WEP please change it to WPA2 or WPA.
Feb 22, 2012 | NetGear WGR614 Wireless Router
Netgear WGR614v9
I believe the checkmark light is to say that the internet connection has been successful. Are the laptops connecting to the router but not the internet?
Connect a PC/laptop to the router via ethernet cable and goto the routers homepage (usually 192.168.1.1 or 192.168.0.1). then double check that your ISP settings have been entered correctly. This should get you online, if the problems persist contact your ISP to clarify your broadband settings, user logon, and that their service is up and running.
Hope this helps, www.PuterCare.com
May 15, 2010 | NetGear WGR614 Wireless Router
Netgear WGR614v9
Try changing/playing with the Channels. Try changing the type of wireless security used too.
Mar 28, 2010 | NetGear WGR614 Wireless Router
WGR614V9 virgin router drops connection
I should first thank you for the clear details you have given about your connection .I will try best to help you.The firmware version can be older so check the firmware version and upgrade it. Try to open the netgear smart wizard page in your wired computer by going to www.routerlogin.com or 192.168.1.1.The USERNAME:ADMIN and PASSWORD:PASSWORD(default).We can troubleshoot this only if this page is opened.In the netgear page at left side blue screen under maintenance->router status check the firmare version if its older version then click on router upgrade and check for the new version from internet(click on check tab) and upgrade the firmware.Hope this solves your problem if not try with different laptop wirelessly connect if you are able to connect then its the computer problem contact your computer vendor.Rate me if i have helped you that will motivate me.Thank you.Have a good day.
Sep 24, 2009 | NetGear WGT624 Wireless Router
I have a Netgear Wireless G router (DG834G) & Virgin Broadband
have u went threw the settings on ur xbox 360 for online? make sure all cables connected properly xbox can be tricky for that
Jul 16, 2009 | Video Game Consoles & Games
I need a manual for the wgr614v9, where can I download it from?
Dear Williams,
Here is the Manual for WGR614v9 , you can download it, from this site:
http://kbserver.netgear.com/products/WGR614v9.asp
Be Happy Always
Regards
Dec 09, 2008 | NetGear WGR614 Wireless Router
2wire router and usb adapter
first u need to connect a pc through wired on the w/l router and go to w/l part and configuge it
Oct 05, 2007 | 2wire (1000-400108-001) Router
Open Questions:
Computers & Internet Logo
5,370 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
