Question about Singer 3116 Simple
What are the seam allowances 1/4 3/8 5/8 lines?
This may sound silly but what are the seam allowance sizes that are on the machine?
  • Singer Master
  • 7,365 Answers
They are guide lines for when you need to sew a 1/4 inch seams
allowance.
or if the pattern calls for a 3/8 inch seam allowance then you have a
guide line to go by.
some people use them when they sew and some people don't use
them when they sew.
Posted on Oct 30, 2012
I lost my instructions for pattern 5527 (diaper bag). Can you help?
You could contact Simplicity and see if they can help.
or find a free diaper bag pattern on line and use as a guide.
bags arent too difficilt, usually need to interface well, attach pockets, straps, then sew lining to top edge wrong side to wrong side, leaving a bit of the lining or side seam open so you can get inside to attach lining seam allowances to bag seam allowances to hold together.
Simplicity 5527 Diaper Bag in Three Sizes
Feb 28, 2015 | Sewing Machines
How do I adjust the seam allowance to cut 1/4 inch
Hello
To the right of the cutter, on the front cover, there are markings indicating various seam allowances. Placing the fabric edge along the specific seam allowance will automatically cut off the required amount of fabric and the serged seam will be on the seam line. Do a test sample first to ensure that the marked lines refer to the left needle or to the single needle that you are using.
Yes, there is a blade position dial too. It is located closest to you on the left side on the bottom. The larger the number, the wider the seam. Again make a few test samples to ensure the results that you are seeking.
Happy stitching.
Sep 10, 2014 | Brother 1034D Serger Sewing Machine
Difficulty achieving a consistent 1/4 inch seam allowance
Using a straight stitch needle plate helps a lot. The end of the fabric doesn't get drawn down into the zig zag needle hole. The needle plate will cost around $50 but for me it is worth it for accurate piecing.
Aug 14, 2014 | Elna Quilter's Dream 6003Q
Pattern calls for 3/16 seam allowance. What is that in comparison to the marks in my machine?
Well, the normal seam allowance is 5/8ths. Always has been except on crafts and doll clothes. 3/16ths is 1/3 of the normal 5/8ths so I would think, now wider than the width of your sewing foot.
Aug 06, 2013 | Singer 3116 Simple
Machine starts to sew then upper thread knots up on underside of fabric
Do each of these steps one at a time and then test a seam on scrap fabric of the same type.
1. Make sure you thread the machine correctly with the feed dog lever in the up position. (this opens the tension discs, allowing the thread to seat correctly)
2. Make sure your needle and thread are the correct size for the fabric and that you've oriented the needle correctly and have it fully seated into the needle bar.
3. When beginning to sew a seam, always grasp both threads and hold them as you begin to sew.
4. Loops on the bottom of the fabric means that the upper tension is too loose. Tighten the upper tension a little at a time until loops disappear.
Good luck.
Sep 22, 2012 | Brother XL-2610
Need help with seam guide? there are no numbers, how do i know what each line measures?
Firstly you need to ensure your needle is centred, remove the presser foot for a bit of room, lower the needle down into the needle plate, and then measure from the needle to the right to each marking on your needle plate.
If you are in the USA, then I'd guess there would be three markings at 1/4" 1/2" and 5/8". Quarter inch is your narrow seam for quilting but if you are sewing garments, then the seam allowance is usually 5/8", it would be marked on your paper pattern though. Some patterns such as Burda came with no allowance and you need to add them on, again it would be marked on the pattern though.
If you are in a metric country, then it will probably have 10mm, 15mm and 20mm marked. Normal seam allowance is 15mm.
If you have trouble remembering which marking to use, you could always stick a strip of masking tape onto your plate along the line you use for seams until you get some sewing experience.
You might like to visit www.sewing.about.com, Debbie Cosgrove gives loads of very useful information there, a learn to sew page along with some free projects. At the tender age of 10 I recall sewing an apron and triangle scarf in home economics as my very first project on an Elna Star SU, simple projects are best when starting out.
If you are going to sew garments, then you may also like to check out www.patternreview.com, I love this site as members share their experience with commercial sewing patterns, some very talented sewists there; many of them have their own blogs too.
If you can find a sewing beginner class, take it, it will get you started with basic techniques that patterns don't really give you and help with that initial learning curve. And my last suggestion, invest in a good sewing textbook; I've got the Vogue Book of Sewing, and also the The Sewing Book by Alison Smith published by Doring Kindersley; I love this one, loads of great images and its a fresh publication. Bit pricey but if you could always ask a loved one to buy it for Christmas. Feel free to connect to me if you have any other sewing questions, I'd love to help.
Happy sewing
Nov 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a brother VX-950 sewing machine I have a pretty good stitch on top and bottom, put it is still puckering. I tried the tension. What elese should I try?
New needle and make sure it is the right sized needle for the fabric that you are sewing. If silky satin then use a size 70 or even 60 needle sharp. If microfibre then there are Schmetz needles called microtec that are perfect for this.
Also try shortening the stitch length a little. You may still need to finesse the tension a bit. I think this is a front loading bobbin machine so you might try adjusting the tension on the bobbin holder a little bit. It is hard with these as there is no "0' marking to set it to, its just trial and testing.
Also, are you pinning across the seam line at about 3 inch intervals?
If there is still some puckering happening, then perhaps, stop at the end of the seam with the needle in the work, and ease the fabric along the stitching line a bit to smooth out the seam, then do the reversing stitches at the end to lock off the seam.
Also press, press, press each seam. Always press on top of the seam, turn it over and press the underside of the seam, then lie right side down on the ironing board and press the seam allowances open. This sets the stitches into the fabric and finishes off the seam appearance. I always sew with the ironing press on beside me.
You may still be unhappy with the seam result after doing all this - if you enjoy sewing then consider shopping for a higher quality machine - there is a difference in stitching quality between a $400 and $2,000 machine. You could always take a piece of your fabric to a sewing dealer near you and test sew on a European machine, you should see a difference in the stitching quality.
Apr 17, 2011 | Brother Sewing Machines
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Quilting seam allowance
When you turn your machine on it automatically sets up for a straight stitch with the needle centered. Just guide the right edge of your fabric along the line marked 15 on the throat plate and you'll have very close to a 5/8" seam. If you need more precision you can adjust your needle position to the left or the right by using the stitch width and mirror setting buttons.
Jun 23, 2008 | Husqvarna Rose
Singer 3116 Simple Logo
108 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
