Fan won't stay running and temperature sensor flashes
  • 8,617 Answers
Sounds like the fan needs replacement. A faulty fan will shut the set down and the tem light will falsh in most cases.
Posted on Oct 28, 2012
2003 Dodge Durango (5.9L V8) won't stay running unless you keep your foot on the gas.
Check temp sensor and TPS, throttle positioning sensor.The power control module,"pcm.is a possible thought.Just check all connections. It is always a good idea to spray WD 40 or equivalent in the connections.
Feb 11, 2013 | 2003 Dodge Durango
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
Cooling fan on 97 sunfire se, 2.2l not running, and is wired to run continuously. Fuse relay is good. Any suggestions?
It's wired to run continuously and it doesn't run ??? Or it does run ??? If it's wired to run all the time an it doesn't , the temp sensor wouldn't have anything to do with it . Fan itself would be the problem . Videos on youtube showing how to test cooling fan .
Oct 24, 2017 | Pontiac Sunfire Cars & Trucks
Radiator fans won't shut down
The fans are controlled by the Engine Coolant Temperature sensor mounted in the coolant hose at the top front of the engine. Disconnect the electrical connector and see what happens. Fans should not run. If that cut the fans off replace the ECT sensor.
The ECT sensor provides input to the Engine Control Module which controls the radiator fan ...Its usually the center sensor connector thats Grey..
Aug 06, 2011 | 1996 Jaguar Xj Series
Engine fan won't come on
IF COOLANT FAN FUSE AND RELAY OKAY.HOT WIRE COOLANT FAN TO SEE IF FAN MOTOR OKAY.IF FAN MOTOR OKAY.THE ENGINE COOLANT TEMPERATURE SENSOR MORE LIKELY BAD.THE ENGINE COOLANT SENSOR WHEN ENGINE COOLANT GETS HOT IT CAUSES ENGINE COOLANT TEMPERATURE RESISTANCE TO DECREASE CAUSE COMPLETE CIRCUIT IN WHICH POWER FROM PCM TO ECT SENSOR WILL SENT POWER TO COOLANT FAN RELAY THEN CAUSE COOLANT FAN TO TURN ON. HAVE ECT SENSOR OR ENGINE COOLANT TEMPERATURE SENSOR CHECK USING CODE SCANNER TO MAKE SURE ITS WORKING BEFORE SPENDING EXCESS MONEY.
Jun 18, 2011 | 1998 Ford Taurus
I have ablack screen and I turn the tv on and the lamp light flashes and the Temp light flashes and will not turn on No Sound and just a black screen
When the temperature light flashes then you have an overheating issue or at least the set thinks you do. It could be a bad temp sensor or as minor as the fan not working or an obstructed air path. The reason it won't come on is it is in protect mode when it senses a high temperature to protect the componenets. You will need to have the sensor check and also make sure all fans are working and there is a clear path for fresh air to cool the set.
Jun 13, 2011 | Hitachi 51F500 51" Rear Projection...
Car is over heating and the fan won't come on
check the fan first. Unplug it and apply voltage see if it runs. Watch you fingers as you test it. If it runs check the temperature switch or temperature sensor. Unscrew it and tie a string to it. attach wires to the connectors and measure resistance with an ohmmeter. The resistance value should change as you dip the sensor in hot water. ( close to boiling). be careful not burn yourself.
Jun 04, 2011 | 2006 Ford Fusion
1995 chevy lumina sensor went out and fan wont turn
How did you determine that the sensor failed. Did the check engine light come on? When you say that the fan won't turn, do you mean that it won't turn on and run or that you can't physically turn it by hand. To determine this, disconnect the electrical connector to the fan and try to turn it by hand. It should turn easily. If it doesn't then it must be replaced. If it does then reconnect the electrical connector to the fan and try to operate it by disconnecting the temperature sensor lead and placing a jumper wire between the terminals of the harness. turn the AC control to AC/MAX and turn the ignition key to on. If the fan runs then the problem is the sensor. If it doesn't then check the fan control relay and any related fuses. WARNING : Use extreme caution when testing the fan circuit. Never attempt to turn the fan with the electrical connector in place. The fan can operate at any time even if the engine is off.
May 14, 2011 | 1995 Chevrolet Lumina
My engine fan is not working
If you have the 1.9 liter engine...
There is a coolant temperature sensor located on the drivers side cylinder head, and if this goes bad, you fan won't run.
You can test this with a live data scanner to verify the issue.
May 11, 2011 | 1993 Saturn SL2
Bought 2001 Lumina.. head gasket was leaking. fixed that n noticed cooling fan motors were not running. Replace all 3 relays n ect n fans started working. Drove it two days n it started runnin hot pulled...
I had a similar problem. Is your temperature gauge pegged to the right as very hot? Or reads always cold, even when hot. If it is a 3100 motor their is a coolant temperature gauge sending unit under the air breather intake that is right next to where you replace the thermostat.
Get a haynes repair manual at a parts dealer, Amazon, or your public library.
On the Chevrolet Lumina, Monte Carlo, & Impala FWD 1995 to 2005 it's under section 3-8 on page 3-6. It goes into great detail, and it's too complicated to explain here. If your sensor is bad, but the wires and fuses are good then the fans won't run.
Your second fan only runs when the air compressor is turning, If your ac compressor is not running then the sensor will not have the passenger fan run.
You have to see if the fan motors are good and then the wiring is good, and no fuses blown. You might blow fuses so have extra blue ones if I remember right. Recheck fuses after testing.
Feb 24, 2011 | 2001 Chevrolet Lumina
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
