Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Cannot get the printer to print in colour-all new cartridges,
New cartridges, have gone through the usual procedure of loading. Will not colour when photocopying or from the computer.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Why does my HP 880C not print black yet prints colour?
Black cartridge might be nozzles clogged, for cleaning go to youtube for cleaning procedures or replace new cartridge.
Oct 14, 2014 | HP DeskJet 880c InkJet Printer
Xerox phaser 6180. Printing 3 blue horizontal lines spaced evenly apart on printed page. New toners. Could it be fuser? transfer roller?
Just because they are new toners, doesn't mean they can't be faulty.
Faults that show in just a single colour are almost always related to THAT colour toner cartridge.
TRY THIS
If you still have your old cyan toner, swap the chip from your new toner and put the old toner in the printer, then test.
If the lines are gone, it's the NEW cyan toner cartridge.
Jan 07, 2011 | Office Equipment & Supplies
I just new printer.But when i want to print using colour,the outcome is just red and blue colour,even the actual colour in the input is green,it will be come out in red colour.How i'm gone to fixed it??
If it is a brand new printer and you are using the host cartridges that came with the printer, then you may face this issue.
You need to try with another set of cartridge.
HP 60 Black Ink Cartridge : part no. CC640WN#140
HP 60 Tricolor Ink Cartridge : part no. CC643WN#140
You may place an order directly from HP ( 1-888-897-8561 OR http://www.shopping.hp.com/webapp/shopping/home.do
After you recv the cartridges, clean inside the printer with a lint free cloth or coffee filter, remove all tapes from the new cartridges.
Install the cartridges and this should resolve your problem.
However if this does not solve the problem, call 1 800 474 6836 for troubleshooting and/or replacement.
Jul 14, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
It is printing everything with a green tint and I had not changed any settings. I have also gone out and bought two new ink cartridges thinking maybe the new one I had was defective. There is no change...
I have personally encountered similar problem in my work. There is no problem with your printer.
Sometimes when either of the inks overflow at the nozzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning your colours from green the right colour. Bring out your colour cartridge. Peel off the seal covering top of the ink cartridge. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nozzle. Clean off the ink. (At the nozzle do not rub only dab). Now press a piece of folded tissue to the nozzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 21, 2009 | Kodak ESP 5 Printer
Have just installed new ink cartridge and colours will not print properly New colour cartridge from cartridge world not had this prob b4
If it's not an original cartridge you can expect problems. I tried remanufactured or OEM type cartridges and lost an Epson and a HP printer to printing problems within a week.
Have you tried carrying out the printhead cleaning and alignment procedures since fitting it ?
Nov 04, 2009 | HP Officejet 6310 All-In-One InkJet...
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
Aug 27, 2009 | HP DeskJet 850C InkJet Printer
No coloured ink showing
Try to remove and reinstall Ink Cartridges while printer is ON. Be sure the it is lock in place on the cartridge holder. If same issue, power off the printer and unplug and replug the power adapter. Check if the error has gone.
Jun 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
Colour cartridge does not print in red
Call tech support. I believe your print head is in need of replacement. Usually they will send you out a new on free - in 3-5 days. They are foreigners (tech support) but they are knowledgable and very helpful.
Feb 19, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a brother 115c, have installed a new cartridge in cyan, now it says there is no cartridge there, is there anyway i can get it to register the new cartridge?
My Brother DCP-115C I have replaced colours Cyan and Magenta both colours still will not print. Ihave gone through the cleaning procedures still will not print these colours
Jan 19, 2009 | Brother DCP 115C All-In-One InkJet Printer
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
