Question about Panasonic TH-42PX75U 42 in. Plasma HDTV
Panasonic S.O.S. code 07
Hdmi inputs dont work
Panasonic Plasma TV TC-P65S2 HDMI INPUT not working
Have you selected HDMI through the source menu? It is a little odd for none of them to work!
Jun 16, 2015 | Panasonic Televison & Video
HDMI input on Panasonic Plasma display stopped working
It is the IO board and connector. Take it to a repair shop.
Apr 21, 2014 | Panasonic TH-42PH9UK HD 42 Plasma Display
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
Mar 22, 2013 | Panasonic 50 in. Plasma TV
Hdmi inputs dont work after lightening storm
Did you disconnect from power the units connected to the inputs? I would guess either the set or something hooked to those inputs got a static hit.
Oct 28, 2012 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have only the cable and hdmi hook into my panasonic 42 plasma and i dont get anything that is hdmi is there other cables i need?
Using your input key on the remote should switch you to the other modes. If you cannot access any HDMI or other input labels, go to your menu, and into the Input Labeling menu (under settings) and make sure you have all the inputs you require enabled. Its possible you (or an out of the box error) put these other inputs offline, which is why you aren't able to access your media from HDMI. If all inputs are enabled, and labeled, double check all the HDMI inputs on the unit. Plug what you are using with HDMI into each port, having the power on and sending information to the television. In some rare cases, I've seen that it doesn't allow access to the HDMI without it providing some source information.
Hope that helps.
Apr 09, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
