Question about Omega Seamaster 300M wristwatch
What year omega seamaster serial number 58885669
What year is this watch
SOURCE: omega seamaster
sounds like an auto wind watch,you must wear this watch most of the day to keep it wound up.to wind the crown must be pushed all the way in.
Posted on May 04, 2007
Cory5468
  • 125 Answers
SOURCE: Omega Seamaster battery
Well maybe if you use a coupon then the price will be lower.
Posted on Mar 06, 2008
  • 65 Answers
SOURCE: Omega Seamaster gaining about 10 minutes per hour
Hi, If under warrantee certainly return it for service. I can categorically tell you it's not a broken mainspring. If it were it would not run period. It's probably not rated correctly however if purchased new this is not likely. If you have had similar problems with other mechanical watches you may be better off with a quartz watch. Problem may have occurred if the watch has been subjected to a strong magnetic field.
Posted on Jul 22, 2009
  • 183 Answers
SOURCE: Why do the Omega Seamaster watches have a second
This is a helium release valve.
The purpose and function of the helium relief valve is a common point of confusion. It has nothing to do with normal underwater diving. Neither does it have anything to do with the depth rating for a diving watch. Helium does NOT seep into the watch while the watch is in water at any depth!
To put it simply, you can completely ignore a helium relief valve. This feature is not used in any way with any form of normal SCUBA diving or anything else that involves less than a multi-million dollar deep sea exploration project.
SCUBA diving activities normally occur at depths of no more than 120 feet. At 250 feet, air becomes toxic due to changes caused by the high pressures at such depths. For those who do very deep sea research, they often use diving bells, dry dive suits, and other types of very deep ocean exploration vessels. In some of these, a highly helium-saturated atmosphere is used to avoid the air toxicity effect.
The purpose of a helium release valve is for people who wear their watch inside the helium-saturated environment for an extended period. Because helium is the smallest atom, it will seep through the watch's seals under the high air (not water) pressures in this environment. If the watch stays in this environment for an extended time, helium will continue to seep in to the watch until the air pressure inside the watch (initially surface air pressure) equalizes to the air pressure in the environment.
This becomes a problem when the vessel is brought back up and depressurized. The helium which seeped into the watch over a couple of days, cannot seep out any faster. The excess pressure inside the watch needs a way to release faster than it seeped in. It is only in this situation that a watch needs a helium relief valve at all. If a relief valve was not on the watch, the excess pressure would likely escape by pushing the crystal out.
But, unless you are in this exact situation, you should never keep this valve open. While the watch is designed to maintain most of its waterproof abilities even when the valve open, it still serves no purpose and increases risk of damage to the watch to do so.
Posted on Sep 23, 2009
Testimonial: "What a totally great reschearched answer!!! Very informative!!!"
SOURCE: how to restore 1968 vintage
I have got a OMEGA Seamaster (1968) and had a leakage accident with it. Please explain me how I could change the mechanism.
Thanks in advance.
My e-mail is jalonsom8@hotmail.com
Posted on Jan 14, 2011
May i have information about omega watches?
Top omega watches internet wide free delivery. For Omega watches, quality, creativity and innovation work together. It can make use of the better of materials to style its watches. visit it http://sbwatches.com/
Apr 06, 2014 | Watches
I have bin given a omega watch four my birtday and i wont to no how mutch its worth the serial numberis 53831642
mcdevito75 here, Omega, outstanding watch, and a Deville REAL NICE, Depending on it"s age and the functions it has I would guess, $225.00---------$275.00 or even more. The Seamasters are the REAL expensive Omegas. Look for a small watch repair shop in your area for further help.
Jul 03, 2010 | Omega DeVille 4730.31 Wrist Watch
Find watch numbers, seamaster automatic
I hope you have Omega Dynamic?!
If yes, then the crown can be removed by appling slight pressure against the watch. The stem inside the watch is made of 2 pieces and the crown can be pulled out. But be careful, there are chances that the stem may break :-)
Sep 07, 2009 | Omega Constallation 1272.70 Wrist Watch
Hi honestfunguy. Take it back! Omega watches are usually guaranteed for 2 years or even 3 years (Co-axial escapement), so you should not have a problem getting it repaired under warrantee. No way should it be be gaining (or losing) 10 minutes per day, let alone 10 minutes per hour. Could be any number of things, from a broken mainspring to problems with the timing regulator, but they are very complex watches and should not be looked at by anyone apart from Omega whilst in warrantee, otherwise you'll probably void the warrantee. Hope this helps; Eagle58
Jun 07, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Omega seamaster professional chronograph
That is something that can only fixed by sending it in to Omega for service. You can take it to an authorized dealer or send it in youself. The customer service info in on there website.
Jun 09, 2008 | Omega Seamaster 2561.80 Wrist Watch
Feb 06, 2008 | Omega Seamaster 2541.80 Wrist Watch
Omega seamaster
Jan 10, 2007 | Omega Seamaster 2232.80 Wrist Watch
Omega Seamaster 300M wristwatch Logo
27 people viewed this question
Top Omega Watches Experts
DROPNDEAL
DROPNDEAL
Geoff
Are you an Omega Watch Expert? Answer questions, earn points and help others
