NSM Hit120 Jukebox.
Thanks for the info. it now selects and attempts to play, but as soon as the tone arm rests on the record, it immediately rejects and places the record back in the rack and the player tracks back to its' park position. You were spot on with your description of the encoder, so I have every confidence that you have extensive knowledge of this Juke. Thanks again for your interest and help.
  • skinnersunit Jan 07, 2009
    Thanks for your input, but this machine doesn't have an opto sensor on the tone arm. Instead it has a small magnet on the bottom of the tone arm which activates a reed switch when the tone arm magnet gets close to it at the end of the record play. Have temporarily disabled the reed switch by cutting one of the two wires attached to it, but no difference. It still rejects.
    Hope you can help.
  • 3 Answers
There is an opto sensor the gets blocked when the tone arm is at the end of the song. It looks like a black u mounted on a circuit board. The flag that interupts the sensor is on the tone arm. The opto must be dirty so it thinks it's at the end of the song and continues to the unload sequence dispite the tone arm having just started playing.
Posted on Jan 03, 2009
Have a Rockola Model 481. Arm swings over when record drops but as soon as it swings over to start position it resets.
There are a couple things that could do would be if the reject bottom was stuck in or the wiring going to it shorted out, take an ohm meter and make sure there isn't a low resistance across it..The other thing I can think of is the reject switch on the tone arm is closed or out of adjustment and thinks the tone arm is at the end of the record so it rejects as soon as the needle sits down on the record
Nov 14, 2017 | Audio Players & Recorders
Rock ola 460
Contact the Guy at American Restoration in Las Vegas NV, he rebuilds these.
Jul 13, 2017 | Audio Players & Recorders
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
Wont eject disc
1. power OFF
2. UNplug cord at wall
3. Turn ON jukebox (w/o power cord plugged in)
4. Turn OFF jukebox
5. Plug cord into SURGE PROCTOR (not wall, not simple power strip)
6.Turn ON jukebox.
7. If it doesn't work, try once more; otherwise ... *sigh* repair/replace..
Sep 01, 2009 | Audio Players & Recorders
NSM Hyperbeam Wall mount Juke box
if you get error 61 it means check cd and exchange,or cd changer or at the most it could be the decoder board you could try jukeboxworld good site for manuals etc
Jun 03, 2009 | Wurlitzer Jukebox CD Player
NSM Hit120 Jukebox
there's another switch inside/right near that encoded that clicks when the record is loaded. If loading/scrolling motor never stops during load unload i'd look there
Jan 07, 2009 | Audio Players & Recorders
NSM Hit120 Jukebox circa 1970s. Fails to select and play.
Sounds like the encoder on the mech. It's the black gear on the lower right that rotates through the box with the wires soldered to it. (right next to the white gear that makes the whole unit go left to right.) It uses an optical sensor to count the holes in the wheel/gear. It's not registering either because of the wiring or more likely gunk inside the unit blocking the optical sensor.
Dec 11, 2008 | Audio Players & Recorders
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
287 people viewed this question
