Question about Baumatic Washing Machines
Hi i have a baumatic bk6el/6kg washing machine at will not spin out on its final spin.
  • robert low Oct 28, 2012
    thank guys but got it fixed made a hook with nail of all things, cheers
    Problem Solver:
  • 10 Answers
May be your timer, go to Britishjames.com
Posted on Oct 27, 2012
4 Suggested Answers
  • 31 Answers
SOURCE: need a manual for the Baumatic BK6EL/6kg just
www.baumatic.co.uk
Should be contact information here to request (or possibly download) a manual.
Posted on Apr 19, 2009
rickead1
  • 1998 Answers
SOURCE: Baumatic BK6EL washing machine will
One of the most common problems encountered with washing machines that need repairs, including Baumatic machines, is no water coming into the machine or the soap not being taken from the soap dispenser box. There are two main reasons why this could happen, 1. because the water has been turned off inadvertently from somewhere, or 2. because the water inlet valve as become faulty or blocked.
If your appliance is not taking in water the first thing you need to know is if the problem is with the hot or cold supply, to find out you can put your appliance onto a white wash cycle and start the machine this should bring hot water into the machine and you will know within a few minutes if the hot water supply is working or not, and to find out if the cold supply is working or not select stop/reset and then select the drain or spin cycle and this will empty the machine of any water, now select the rinse cycle and this should bring cold water into the machine and you will know within a few minutes if the cold water supply is working or not, once you are sure of the results select stop/reset and then select drain or spin again to empty any water that may have entered the appliance.
At this stage you should know whether the hot or cold supply is at fault, the next thing you need to check is that the water as not been turned off inadvertently, check both the stop **** and the washing machine connector valve/s, to see if you can tell if it as been turned off or not, if you think it as, turn it back on and do the hot and cold cycle test above for the cycle that failed, if the water is still not coming into the appliance you know need to turn the water off from the washing machine inlet valve/s one at a time and slowly disconnect the the inlet pipe/s from the washing machine side and point the washing machine inlet pipe it into a bucket and then turn the water back on, you should be checking to see that the water is on and also that the water pressure is OK.
There is a good chance your appliance could be working OK now, but If the test above shows the water is on and the pressure is OK but the washing machine is still not taking in water, you will need to have t the water inlet valve and or the water pressure switch and water pressure chamber tested, the diagnosis procedure covered here will work for Baumatic washing machines that need repairs, it will also work for most other makes.hope this helps
Posted on Aug 11, 2010
supertech6
  • 513 Answers
SOURCE: We don't have an instruction manual for our
This has a strong indication that the machine needs a controller. A controller can be from $80 - $400 depending on model and type. Good news is they are generally easy to change. I recommend a new knob with the controller as you will likely break it getting it off without knowledge and special tools.
Check this website for parts:
http://www.prontoparts.com.au/
Posted on Mar 22, 2010
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
Problem with hotpoint aquarius wml520p 6kg 1200 spin washing machine doesent go into final spin
Have you checked the filter if fitted? Sometimes washing machines will not spin if they're not empty.
Jan 19, 2015 | Hotpoint Washing Machines
I have a baumatic class a 6KG 1100rpm washing machine and it is showing error code F04 - what does that mean? How do I fix it? Please help Rachel
I have had this same problem - you need to clean the drain as a starting point. You can do this by removing the front panel at the bottom of the machine (you will need a Torx head screwdriver) then gently unscrewing the filter on the bottom right hand corner. Keep a tray underneath though - as water will flood out as you remove the filter! If the filter is full of fluff, you should be able to fix the machine by cleaning it out and then putting it back in.
Dec 19, 2010 | Baumatic Washing Machines
Simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Jun 19, 2010 | Washing Machines
We don't have an instruction manual for our Baumatic BK6EL washing machine, bought second hand. The machine seems to keep filling and rinsing and needs to be halted manually.
Mar 22, 2010 | Washing Machines
The machine won't spin , machine will wash but won't do the final drain and won't spin at all :(
It is probably due to a blocked pump filter.
You need to locate and clean the filter.
Jan 17, 2010 | Baumatic Washing Machines
Re Baumatic BK6EL, the washer stops at the beginning of the spin cycle, showing soak, extra rinse, spin lights all on. Thinking it was just an unbalanced load, I readjust the load and press the start...
Hi Same problem but easy to fix.
Remove back cover of machine. Look to the lower end of the bowl and you will notice a stainless steel wire with hook attached. If this is hanging loose that will be your problem. Reattach the hook to the grey coloured lever , it has a hole drilled through it at the extremity. The wire pulls on this lever to disengage the drum brake during the spin cycle.
Oct 27, 2009 | Washing Machines
Not spinning
If everything is working, which I assume is, that is the machine is taking water,spinning etc but not completing the final cycle then you have a fault with your pcb or the the control unit.This is what controls all the unit of the machine to perform a wash, that is it sends the signal to the water valve when its time to take water and sends the signal to the motor to turn etc...
Aug 03, 2009 | Washing Machines
Need a manual for the Baumatic BK6EL/6kg just bought off Trademe no manual with machine
www.baumatic.co.uk
Apr 19, 2009 | Baumatic Washing Machines
Baumatic washing m/c btwm4
check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Nov 25, 2008 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
299 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
