Question about Lexmark Z42 InkJet Printer
My printer will only print test pages ! Non-stop !
Hello. I've got a Lexmark Z42 printer and for some reason, since I changed the last empty cartridge, it will only print test pages. Can you help me please ?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Printer shows it is printing and it just pulls paper through and nothing has printed. I have changed ink and still won't work. I've cleaned print head. It will only print black and not colored on...
A firmware update for your model addresses a number of issues including print quality issues. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Oct 17, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I've loosed my disc and i want to install lexmark Z42 printer to my new computer pls how can i install the lexmark printer without a disc?
Please visit the Lexmark website to download and install the Lexmark Z42 Printer Driver on your computer.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 13, 2011 | Lexmark Color JetPrinter Z42 InkJet
Can't change Lexmark Z42 ink cartridge
You can unplug the printer from the power source. With the printer off, open the cover where the cartridge carrier is. Hold the solid white tape found in the middle inside the printer. Slowly drag the cartridge carrier to the center. Replace the cartridges. Close the cover. Plug printer back to the power source. Hope this helps.
May 03, 2010 | Lexmark Color JetPrinter Z42 InkJet
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
Hello? anybody there?
turn it off, cancel all again, and send more tests, if doesn't work download the printer driver again, if the were still there try changing the usb cable.
Aug 14, 2009 | Lexmark X2600 InkJet Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer prints words on top of each other
Check to make sure that there is nothing preventing the page from being pulled into the printer. Overlapping words is often caused by the paper feed not moving quickly enough, subsequently causing words to overlap and not span the entire page.
If that doesn't work, let me know and we'll troubleshoot further.
May 15, 2009 | Lexmark Z42 InkJet Printer
My lexmark z43 does not work on my windows vista
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:290:0:0
Click on the above link and select your operating system and Download the drivers.
Thanks, APT
Mar 24, 2009 | Lexmark Color Z43 InkJet
NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Sep 05, 2007 | HP LaserJet 5000 Printer
Lexmark Z42 InkJet Printer Logo
77 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
