Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
Grasshog nst2018 line wont feed properly - Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
  • 313 Answers
SOURCE: My grasshog gh600 wont feed
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Posted on Jun 26, 2008
  • 313 Answers
SOURCE: black and decker grasshog trimmer line feed problem
email publication@bdk.com or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Posted on Jul 28, 2008
SOURCE: Can't remove casing for B&D Cordelss Grasshog (NST2018 Type 2)
These are the steps to open the clamshell/motor housing for the Black and Decker 18V Cordless Trimmer Model NST2018. The orange clamshell has two plastic clips that engage two recesses inside the black plastic ring. You use two screwdrivers to disengage the clips and seperate the black plastic ring from the orange clamshell. Follow these steps: Wrap tube assembly in a small towel and mount in a large bench vice securely. You will notice two small openings at the top of the black plastic ring at the top of the orange clamshell. The next steps require two people. Person one inserts a flat-bladed screwdriver into into each of the small openings at the top of the black plastic ring (two screwdrivers). Using the tube assembly for leverage, pry the black plastic ring from the orange clamshell with enough force to disengage the orange plastic clips from the black plastic ring. Person two pulls the orange clamshell/motor housing away from the black plastic ring/tube assembly along a straight line (same axis as the tube assembly). After you've separated the motor/clamshell housing from the black plastic ring, remove the six screws and open the clamshells.
Posted on Mar 14, 2009
  • 64 Answers
SOURCE: Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Posted on Aug 07, 2009
How to I feed the line in my Black and Decker battery GrassHog weed eater
There are 2 models one has a extendable handle these are both Grasshogs, if i was told incorrectly please contact me. Thank you
12" 18V Cordless Trimmer and Edger MODEL # NST2118 Page 10 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90559891,NST2118.pdf
18V Cordless Trimmer and Edger MODEL # NST2018 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90509965,NST2018.pdf
Jul 09, 2011 | Black & Decker Garden
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
Aug 20, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Need Replacement Battery for CST2000
243215-00 is the part number for the Grasshog's battery pack, but that part is now obsolete. However, you can get the internal battery (part #243213-00 )itself from Amazon for $35.99:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
Jun 28, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Black and Decker Grasshog auto line feeder just spits line out non-stop. Tried lots of things but nothing seems to work.
I'm gonna take a guess and say you re-spooled the line yourself. If you did you may have put too much line on the spool. The max. is 30', but I've found that that can cause jamming, which forces out more line, if not done perfectly. Reduce the amount of line by about 5 feet and you should be OK.
Apr 10, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Line will not advance line is not crossed in spool
Rewind the line and make sure you wind in the direction of the arrow on the spool. Not an unusual situation.
Mar 31, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Remove lower clamshell from B&D grasshog NST2018 T2
Read about product details,features and reviews of Black & Decker NST2018.Check them out and order yours today!
Apr 29, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
64 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
