Question about Samsung CLP 300 Laser Printer
Looks like toner is not sealed to the paper.
Print quality is great on plain paper, but horrible on cardstock. I've already changed my paper to a thinner cardstock. Print looks crumbly. Toner rubs right off.
  • russellhanco Jan 05, 2009
    I have the same issue printing on anything other than 80gsm plain A4.
    The problem is either that it is applying too much toner and so the fuser cannot fuse it to the page or that the fuser is not hot enough to really seal it on.
    I have played with the settings and turning the toner level down stops the problem but also makes the prints look washed out.
    has anyone any ideas?
  • 104 Answers
The machine is only designed for 80gsm paper. you can change paper type through printer options in printer manager to card stock. it wil probably not work though as it is really only designed for 80gsm paper. the toner need to be heated to 200oC inorder to fuse to the paper cardstock absorbs less heat than normal paper.
Posted on Jan 06, 2009
I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Sep 26, 2012 | OKI C9650HDN Led Printer
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Cleaning the Xerox Workcentre Pro 575
More than likely, you have a bad toner cartridge.
Nov 12, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
How can I change the print quality of faxes received on my Brother IntelliFAX-1270e machine. Paula
You normally can't control the print quality of what you receive. You might try a new toner cartridge.
Aug 14, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Print
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges. Manually Cleaning Inside the Printer Steps: 1. Unplug the printer from the surge suppressor. 2. Remove the internal paper trays. 3. Remove the toner cartridge and place it on a piece of scrap paper. 4. Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer). 5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided. 6. Wipe away dust and spilled toner. Remove paper fragments. 7. Clean the rollers, but don't touch the sponge roller. 8. Replace the toner cartridge. Tips: To remove unfused toner from the rollers following a paper jam, print 5 to 10 blank pages on scrap paper. Wipe toner from clothing if necessary, then immediately wash toner-soiled clothes in cold water. Go to your printer manufacturer's Web site (see Related Sites) for detailed cleaning instructions. Warnings: Don't use any liquid cleaners inside the printer. Initiating Automatic Cleaning Through Printer Software Steps: 1. Open the printer software by double-clicking on a printer icon or specific printer utility program, or opening a document and then selecting Print from the File menu. 2. In the printer software, look for a button labeled Options, Troubleshooting, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.) 3. Follow the instructions on the screen. 4. Repeat the cleaning process if the results aren't satisfactory.
Jan 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
Samsung CLP 300 Laser Printer Logo
238 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
