Idm9 ihome repair - Audio Players & Recorders
I dropped my ihome speaker in the snow and now it has a buzzing sound. I can still here the music and it's not holding a charge.
For the 20$ they cost, I believe it's not worth to repair it, unless you have a tech in family. So.. 20 $ lost. Buy a new one. They are disposable
Feb 27, 2015 | iHome Audio Players & Recorders
Tip
How to connect an my iPod Nano 3rd Generation to an iHome
<p>Your iPod nano to a device like the iHome to boost output audio or video to a TV in your memory. The iHome also charge your phone as it is docked. You need to take steps to ensure that your iPod will be able to successfully dock the iHome. Once your iPod is well prepared, so you get the most out of your drive for iHome. <br /> <p><br /> <p>1. Connect your iPod to your computer and launch iTunes. <br /> <p><br /> <p>2. Click "Help" from within iTunes, click "Check for Updates". <br /> <p><br /> <p>3. Select "Yes" when asked if you want to download and install updates. If no updates are available, disconnect the iPod. <br /> <p><br /> <p>4. IHome Connect your unit to an AC outlet. <br /> <p><br /> <p>5. Remove the protective layer of your iPod Nano, if applicable. <br /> <p><br /> <p>6. Let the iPod Nano in the dock with the front facing you. You will feel it snap into place. <br />
on Jul 21, 2011 | Computers & Internet
Remove battery for idm9 to reset it?
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 16, 2012 | Cars & Trucks
My ihome want charge my iphone 4
Your iHome may be an older model with an the wrong charge type. Different iPhone / iPod generations use different charge voltage with iPhone requiring a higher voltage than your iHome gives. My suggestion would be to get an adapter that should fix the problem.
Jun 02, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
I got water on my ihome while it was plugged in and now none of the buttons will work but the time and what not still works.
water damage is not really something you will be able to fix on an ihome you can try sending it in to be repaired however and it may even be covered under warranty.
Mar 02, 2011 | Audio Players & Recorders
I want to play a Zen V on an ihome (portable speakers)
there is a double jack wire that should have come with your ihome plug one end ito your zen head phone hole and the other end in the back of your i home thats how mine works idk about yours but it should work the same for all ihomes
Nov 01, 2009 | Creative Labs Zen V MP3 Player
Problem with ihome and ipod nano.
yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
http://www.ihomeaudio.com/products.asp?product_id=10186
Dec 25, 2008 | Apple iPod nano
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Open Questions:
175 people viewed this question
 Grubhead
Grubhead
