Then you see on the video all the wires are nicely connected but i don't know how to active de sub output on the radio someone can help me?
    Master:
  • 444 Answers
It will not work ,You do not hook up a car amp end sub to any type of home system, Your lucky that you didn,t fry (Everry) Thing, Have a couple of more drinks. This is comeing from a (Retired) Certified Electronics (Technician) With over 35 (years) Expierance under my (Belt)
Posted on Oct 27, 2012
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
Can i replaced my inactive subwoofer into active?
Only if your amp has an output suitable for driving the active sub bass speaker.
Usually you will looking for a pir of rca/phonos marked mono sub pre out out or something that indicates a line level signal output, check the manual for your amp.
Do not connect an active speaker to a high level amp output as this will damage the equipment.
Hope this helps
Thanks for using FixYa
Aug 17, 2010 | Panasonic Audio Players & Recorders
I put an after market cd player in my 2003 acura 3.2 tl type s. all the speakers are working fine but i am not getting any sound out of the factory subwoofer, it is not working. any idead what i did wrong...
You got to connect the blue amp turn on wire. If still dont work. then you got to find the factory amp find the two wires that sends frequency signals to the amp. You will see a total of 7 wires. So you've got to use process of elimination. Use a multimeter.
1.Constant 12 Volt
2. Ground
3. Amp turn on
4. + output wires going to the + of the subwoofer
5. - output wires going to the - of the subwoofer
6 + input wires going to the radio harness
7 + input wires going to the radio harness
6 & 7 are like the rca's you plug in at the input of an aftermarket amplifier and and on the other end plug in the output subwoofer of the Radio.
So on a factory amp you wont see any RCA's its all wires. Once you find the first 5 just remember the last 2 wires.
If you want your radio to control the gain and volume of the Subwoofer get a long RCA plug it on the back of your radio that says sub output and then cut the other end of that RCA and connect the positive the + input wire on the amp and the negative to the negative input wire on the amp.
If you dont know whats positive or negative just go ahead and connect it and experiment. You will know if your in phase when the subs sound boomy. Then the connections are correct. If it sounds Tinney then the connection is out of phase. solder then tape all connections with black electrical tape. Dont leave any power wires exposed or else cause a short and blow fuses.
Good luck
Apr 07, 2010 | Car Audio & Video
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Wen radio is turned up ampp goes into protection
No diagram but you can printthis out. Choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) You need to put the settings to low hertz and no high settings. Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides!). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps
Oct 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
I have a jesen ka5 5channel amp plus mono and i dont know how to hook up the subs to the mono
Ok, you're going to choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps.
Oct 01, 2009 | Jensen Car Audio & Video
No sound from Sub.... from my Denon AVR-2700, not AVR-3300, Yeah its old!
if the subwoofer is on in the reciecer settings then maybe the amp is not getting the signal or the amp is not amplifying
try unplugging the output of the sub then turn off the reciever for a min. then turn it on wait , then plug the sub in
if that don't work then test the sub output with a stereo that has a audio input
also test the subwoofer with a audio output to it( only a positive and a negitive wire for sub)
Oct 26, 2008 | Denon AVR-3300 Receiver
Subwoofer: Active or non active?
Hello Smegboy,
Yes, you are right. This receiver is rated at 100WRMS output in all 5 channels (2-front, 1-center and 2-surround) while in Dolby Pro Logic operation. The subwoofer output is line level only (not amplified), which means you need a powered subwoofer to be connected to this output. A non-powered subwoofer could be used but, you need an additional amplifier connected to the subwwofer output from the receiver to drive it.
Let me know if this helps.
cancerags
Dec 29, 2007 | Technics SA-AX710
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
