Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Convergence will not line up after replacing ic & resistors
I replaced the Ic's and resistors on my Philips 51pw9303. The red convergence will not line up. Setting it to factory settings makes it worse, until I go in manually and redo the blue and red. Blue goes all the way together the red has a one inch gap. I do not have original remote.
  • 4 more comments
  • tnorton2006 Jan 04, 2009
    We did not just the ones burned out, we will do that today. And the Chassis is a DPTV 345.
  • tnorton2006 Jan 05, 2009
    I did try this, however the original remote does not work. I could not get the universal remote to work. I tried several buttons, any other suggestions?
  • tnorton2006 Jan 14, 2009
    Ladywiin,T
    Thank you so much for your help. I finally found a remote and replaced all resistors, the pic looks better but still won't line up.(Red) I tried the code you gave me and it is not powering up???
  • fabianmansfi Jan 29, 2009
    MY RED WONT LINE UP AND SEEMS TO BE WAVIE. WHAT DO I DO?
  • tnorton2006 Feb 05, 2009
    We actually did replace everything, and still have the problem. Is there any way that the board would need to be replaced? It looks as if the copper is separating from the board. Or should we just try to replace the resistors or the chip again? Looking at the set it seems to be the left side that is the warped.
    Thank you so much for your advice and knowledge.
  • ladywinn
    ladywinn May 11, 2010
    Did you CK all 6.8 ohms resistor ? What is your Chassis # PTV710 or PTV 910 ??????
  • Philips Master
  • 3,459 Answers
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your conconvergence will not line up after replacing ic & - 2c07611.pngips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
  • Edward
    Edward Feb 05, 2009
    You should not need the board.  Lets go back to the basics.
    Goto your convergence menu using the remote.
    On the remote press - menu - picture - convergence I believe.
    Try to adjust the RED - up - down - left - right.
    Do the same for the blue.
    Does it work in all directions?
    If so the convergence chips/resistors should be ok.
    If it does not work in all directions one or more chips or resistors may be dead again.  Or it may be a bad solder joint.
  • Philips Master
  • 5,138 Answers
Do you know How to Enter Service Menu for setting convergence?
With set off Press 0-6-2-5-9-6-Status Set should come up in service mode when done turn power off on front of TV this is to save new settings. there is 3 ways of entering convergence ,let know if this works.
Posted on Jan 05, 2009
  • ladywinn
    ladywinn Jan 05, 2009
    OK call local TV Shops ask if they might have a extra handunit That will work. You can also order correct remote online for your TV. CK pawn shops sometimes they have extra remotes they sell for 5.00
  • ladywinn
    ladywinn Feb 07, 2009
    You may need to just replace the convergence board.
    Problem Solver:
  • 11 Answers
If red is square and off proportionately, use the red centering rings to close the gap.
Posted on Jan 04, 2009
The manual converge is all unaligned and I can't get it back together and now I can't watch tv without seeing all colors
need to repair the comvergence ic , and maybe replace 2 resistor , this repair is about $250 , i would recomend u to hire a tv tech for this job , because after they replace the ic they may has to do some aligments
Aug 26, 2010 | Philips 51PW9303 51" Rear Projection...
Color won't converge
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Philips 51PW9303 51" Rear Projection...
Convergence bad
resistor along the convergence are 2Watt size or less. they are easy to find as all of them are in pairs. if you find one is not the same on the other, then replace that resistor. change the 2 convergence IC at the same time. let us know.
Mar 22, 2009 | Philips 43P8341 43" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence on a Philips 51pw9303 rear projection TV
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 12, 2008 | Philips 50P8341 50" Rear Projection...
Which IC is for red convergence?
you need to replace both because they are both linked together with the green as each IC controls one color fully and half the green, so when one IC fails that places a strain on the other IC through the green, so that one will soon follow. You need two STK392-120 ICs and you will also need four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link with free installation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Sep 08, 2008 | Philips 60PP9352 60" Rear Projection...
Philips tv 102cm rear projection
You need to replace both convergence ICs they are STK392-120 and you will also need 4 of the 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures.
Aug 01, 2008 | Philips 51PW9303 51" Rear Projection...
Philips HDtv model 51pw9303/17f double vision red shadows
you need to replace both of the Convergence ICs STK392-120 you can get replacement ICs at the following link, and they provide free installation instructions and free on line tech support.
Heres the link.
Apr 22, 2008 | Televison & Video
51PW9303
By 7045 cap 2061 and resistor 3148 and 7044 should be the only thing.
Apr 01, 2008 | Philips 51PW9303 51" Rear Projection...
Auto convergence
Bull!!!!!!!!! i dont think he knows what hes doing....
you can send the board into ptscorp.com have them check it out, it's the board with big black iC stk392-XXX send that one in, you convergence is done thru the menu system.
Feb 15, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
308 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
