Question about Sub-Zero Refrigerators
I have a Subzero. I left the butter door open and tried to shut the door. The butter door knocked off the cover to the lights. It took me a few minutes to get the cover back on. Of course, the lights went off. I left it shut for 3 hours and it never reset. I tried turning the circuit breaker on and off and that didn't work. The refrigerator is only 2 years old. The lights are not burned out. Please advise of any other ways to reset this. I hear no noise from the unit.
2 Suggested Answers
  • 71 Answers
SOURCE: sub zero stopped working after door left open
whe n you left the door open the fridge have a sensor. and turn the LIGHTS OFF. close the fridge let it cool again.
Posted on Apr 02, 2010
Dome lights stay on when I turn of engine in 2000 Ford Range
the dome light is on a time delay . close the door and wait a few seconds or minutes .
Oct 22, 2017 | Ford Cars & Trucks
Why were Bulbs so hot they melted the lens and melted butter.
most likely door was left open or door switch is faulty leaving light on when door was closed. also check bulb for proper wattage while your in there
May 11, 2014 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
My subzero is cold, but not really cold
it could be the damper door isnt opening fully due to ice or the cold control is bad,or the motherboard that electronically operates the unit is bad,clue:: if you have recently burned out lights in the refrigerator and the digital temp read-out is now out this is the board gone bad,if you replaced the lights and now they dimly flash when you open the door and you have a rapid clicking noise in the rear area its the relay trying to latch,but the burned board wont let it,you will see the burned area upon removal on the plastic cover and board trace is burned away
Jan 26, 2010 | Refrigerators
Subzero door left open and now motor won't start
yeap. wait to cold back. the fridge have a sensor to shut the lights off. the reason; LIGHTS REALLY POWERFULL. CAN BURN THE LIGHT COVER
Jul 15, 2009 | Sub-Zero 601R
Power shuts down when I try to close or open
Your motor may be working too hard anad ripping the reset button on the garage door,
Try increasing the power on the unit ( should be some type of dial.) or the door may be jamming up somewhere, Try disconnecting the opener from the door and see if it goes up easily, the door might need service
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Interior Light sometimes will not shut off in Ford Ranger Pick up
If I am not mistaken, the plunger is located in the door with the latch. Most of the time you can just pull the door panel off and adjust the switch. After opening and closing the door, they get knocked out of adjustment. I sincerely hope that this helped you. Take care and best wishes.
Bryon
Mar 20, 2009 | 1997 Ford Ranger SuperCab
SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Nov 30, 2008 | Sub-Zero 561 / F
Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
May 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
