Question about Refrigerators
No inside light in older Kenmore refrigerator
The place i rent has a much older Kenmore refrigerator. The inside light is missing. The place where the light goes is snugged up so close to the back of the frigerator that i can't get in there and see what kind it takes. Any suggestions? Thanks
  • 306 Answers
Most refrigerators take the same size. make sure you get a 40 watt appliance bulb. ken
Posted on Jan 03, 2009
Refrigerator delivered today, think there are some missing parts.
You should contact the provider of your Kenmore Refrigerator.. neither Fixya nor me, a Fixya user like you, know anything about the artifact you bought.
Jun 19, 2015 | Kenmore Refrigerators
Kenmore efrigerator not cooling or freezing food
Assuming the cooling control is turned on, you possibly have a bad main circuit control board. If this is an older refrigerator with a mechanical thermostat, the thermostat is probably faulty.
Oct 06, 2014 | Kenmore Refrigerators
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
My kenmore elite model 52603100 does not keep the refrigerator cold anymore.It gets some cold air from the vent thats at the bottom inside the meat/veggie drawer but i feel no air from the others.The...
Please double check the Model Number and I will attempt a solution at that time. After this post I will no longer be able to place links. There shoud be a prefix like the 564. before the number. I did try to find this model but something in the model number is missing. Could you also look into back of freezer to see if there is a frost line building up? Here is another example, Click Here=>
Kenmore - Who Made It for them?
Thanks for understanding, Sea Breeze
sea_breeze_18.jpgSea Breeze
Dec 10, 2010 | Refrigerators
Hi, Please tell me how to change the temperature on my elite kenmore.
Klay421 --
Which model Kenmore Elite refrigerator do you have? If you have one of the older manual models, the thermostat is located inside the fridge side. If you have a newer model with digital controls you need to press and hold the the ON/OFF button for 2 seconds until the digital displays for temperature for the Freezer and Refrigerator lights. The Up/Down arrows allows you to adjust the temperature. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore Refrigerators
I need a wiring schematic for kenmore refrigerator model #363.58067892\ where can i find one?
Usually somewhere inside the machine. Typical places are in the cover for the defrost timer or pasted to the inside of a rear cover. Sometimes folded very small. PS: Your model was made by GE
Sep 20, 2009 | Kenmore Refrigerators
Trying to establish approximate age of old Hotpoint Refrigerator
http://www.waptac.org/sp.asp?mc=techaids_refrigerator_energyuse
Looks like between 82-84
Jun 25, 2009 | Refrigerators
Light switch on a older kenmore refrigerator, how to replace
Most light switches snap in place. If there is no apparent screw and the switch seems to have an adequate lip all around it, use a putty knife or butter knife push under that lip at one of the shorter sides and gently try to pry it up. It should pop out. the two wires are usually attached by spade connectors that just pull off. Doesn't matter which wire goes on each. Sears should be able to get a new one. But before you go that far be sure the bulb is not burnt out first. You should also take the switch with you to sears or have a friend test the switch to be sure it is truly bad..
Feb 14, 2008 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
