Question about OEM Systems ATX P4 350 Watts Power Supply ( Channel Well OEM ) (PS350) Power Supply
How many amps does a 350 watts power supply have?
  • neil700 May 11, 2010
    Amp draw varies depending on how many devices are connected (i.e. drives, motherboard, fans, etc.) Also, specs vary from power supply to power supply, despite being 350W.
    Champion:
  • 254 Answers
Should be written on the power supply on a specs sticker
hop this helps
Posted on Jan 03, 2009
3 Suggested Answers
  • 310 Answers
SOURCE: pyramid 35 amp regulated power supply
Use specified power supply by the computer.
Posted on Feb 26, 2008
ginko
  • 19396 Answers
SOURCE: Power supply Dell NPS-200PB-73M
You can buy it here.
Posted on Mar 01, 2008
I have a 2000 w volfenhag amp and a 15 in cadence 350/600 rms watt sub, what gauge wire should i use?
I would use a 4 gauge wire for the power supply to the amp and a 4 gauge neg of the amp
Jun 25, 2016 | Volfenhag Car Audio & Video
Antec SL350 (smartpower sl350) 350-Watt Power Supply circuit diagram
As I told someone before I have been the computer business for many many years and have never needed a schematic. I am curious why?
Nov 13, 2012 | Antec SL350 (smartpower sl350) 350-Watt...
Power supply seems to work fine until it has a load on it. Puts out 13.8 volts, but will only handle about 2 amp load before the overload protection kicks in. My 2 amp load test is an 1157 light bulb and...
Note: I'm answering your post with the assumption that you plan on using this power supply with a computer. If this is not your intention, please disregard my solution attempt.
You likely already know this, but if you are powering a computer you're going to need a power supply with more wattage. I would recommend nothing less than a 350 watt power supply.
Follow this link to calculate how much power you need to run your computer: http://www.extreme.outervision.com/psucalculatorlite.jsp
If you're not ready to give up on your 270 watt power supply, then remove all PCI/PCI-E devices, USB ports, extra fans, non-boot hard drives, extra DVD/CD drives etc. one at a time until the computer powers up. Anything you can do to reduce the load on the power supply will help.
Good luck and thanks for using FixYa.
Mar 08, 2011 | Pyramid PS14KX 270-Watt Power Supply
The fuse is blown and the Model DX-PS350W is discontinued - what other power supply can I purchase that is compatible
you can use about any power supply you want as long as the physical size is the same. stay away from the really cheap ones. they weigh half of what a good one does and they cause problems with the computer. i did see amazo has a 400 watt Dynex on sale now, here is the link
http://www.amazon.com/Dynex-DX-PS350W-350-Watt-Power-Supply/dp/B000EVOOWA
also newegg.com is a trusted site to buy computer parts they sell the cheap ones as well as the top of the line and most all have user reviews.
Feb 14, 2011 | Dynex (DX-PS350W) (DXPS350W) 350-Watt...
Power Supply, Computer wont Turn on
Possible Power supply troubles.
1. Noisy Power supply Fan,,,,,
2. Burnt smell
You can buy cheap Power supplies that will last about a year & half for about $20. Or you can spend up to $100 + dollars.
Make sure you the power supply you pick has at least 300-350 watts or more.
Dec 19, 2009 | Codegen Computers & Internet
Ultra 350 Power supply very loud fan
It's not normal for the fan to be loud, what makes them loud is either a build up of dust on the fan blades or the bearings are going on the fan itself.
If the PSU is working fine then you can replace the fan itself from an identical PSU. It does mean taking the PSU out of the computer and fitting the fan yourself.
Alternatively you can purchase another PSU.
Regards.
Aug 30, 2009 | Ultra (9PA3501609) 350-Watt Power Supply
How much ATI Radeon HD 4350 512MB needs power to work?
Go for more watts here. 500 watts or more here. Make sure your power supply has graphics card power supply. Good luck!!
Aug 04, 2009 | Dell 1505FP 15" LCD Monitor
Describe your Black & Decker Power To
No. You will need typically 35-40 watts for a LCD monitor. 20 watt may not even run DVD's on your laptop. Look for something 80 watt or so.
Jul 07, 2009 | Black & Decker Power To Go Cordless AC/USB...
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
OEM Systems ATX P4 350 Watts Power Supply ( Channel Well OEM ) (PS350) Power Supply Logo
183 people viewed this question
Top OEM Systems Computers & Internet Experts
micky dee
Terry Hair
Bill Boyd
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
