How do I get color on a Emerson tv from the ps3?
    Genius:
  • Televison & ... Master
  • 2,432 Answers
You can not get color?. check the compatible system like ntsc or pal secam.
Posted on Oct 28, 2012
Remote control code list for EMERSON LCD TV MODEL #LC320EM2
Emerson LC320EM2.Code: LC"320"EM2 (0320) works for my Sony BR PS3 remote.
Apr 03, 2012 | Televison & Video
When i hook up my ps3 to an emerson 19 in tv with an hdmi cable it says format not supported
LCD Emerson only support screen with a 1440 x 900 720p resolution.
And PS3 has support 1080p or full HD.
You must arrange output HDMI resolution to 1440 x 900 or to 720p.
thanks.
Mar 21, 2011 | Emerson LD195EM8 19 in. LCD TV
I just bought a used ps3 i hook it up to my emerson hd tv and it shows format not supported , i then hooked it up to my poleroid hd tv and it works fine this all thru the hdmi cable
What are the specs on your emerson, does it support 1080p? Make sure you have the right settings on your ps3. If your emerson supports 720p and 1080i then it will not give you a 1080p picture and you might run into issues.
Mar 06, 2011 | Televison & Video
Resolution mismatch when i hook up my ps3 to it.
hook the appropriate inputs (red white and yellow) on the side of the video input on the emerson tv. Power up tv and be sure it is on the video input screen. Be sure your PS3 is plugged in as necessary, PS3 is in the off position. Turn PS3 on and hold the power button on for 7 seconds until you hear the PS3 beep at you twice (wait for 2nd beep) at that point the PS3 should boot up on your tv monitor - you are resetting the resolution by holding the button down
Dec 22, 2010 | Emerson LC320EM8 32 in. LCD TV
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Emerson 32in flat panel has a resolution mismatch with my ps3
I had the same prob,first thing u need to do is to hold on ps3 power button for 4-6 sec until the ps3 resets and turns off.Next unplug and replug yr hdmi/red white and yellow wires in.Then turn ps3 back on it should adjust in 8seconds.
Sep 07, 2010 | Emerson LC320EM8 32 in. LCD TV
PS3 hdmi generates a not supported format error message on my emerson lcd tv
your ps3 is set to work on a 1080p tv you can change the pixel setting on your ps3 by holding the power button down while youe console is running until it turns off let go and hold your power button down again when your console turns back on your tv wil ask you about the hdmi device its found unless you failed, good luck n00bs
Jan 10, 2010 | Emerson Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
