Question about Yamaha HTR-5930 Receiver
Can't get tv sound to run through yamaha htr 5930
Cable is directly connected from the wall.
SOURCE: my yamaha htr 6050
Make sure your audio output on your PS3 is configured properly. You have the ability to chose which port the audio is coming out of.
The 6050 does NOT process audio signals coming in on the HDMI port. The amp is weak, I had one. With the 6050 you will have to use the AV multi coming out of the PS3 and use the special cable that came with the PS3 to convert that signal to the RCA and connect that to the 6050.
Posted on Jul 27, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Posted on Mar 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: Yamaha amplifier HTR 5930 is not sending sound to
... Incorrect setup; incorrect speaker definition; speaker B selected instead of speaker A.
Posted on Jan 19, 2010
Testimonial: "Thank you. A simple solution for a non technical person."
Nomodo4u
  • 863 Answers
SOURCE: how do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Use HDMI because they combine picture and sound in one convenient cable. You can buy the cheapy ones because they work the same as the pricey ones with no degradation in sound quality or picture.
Posted on Feb 18, 2010
How do I reset my Yamaha HTR-5930 receiver back to the manufacturers settings
Hello there
A combination of 'standby' and 'straight' buttons
You follow the procedure on page 65 of the user guide
available to download here if you have lost it.
http://download.yamaha.com/search/result/?site=usa.yamaha.com&language=en&search=HTR-5930
Sep 24, 2014 | Yamaha HTR 5930 - AV receiver - 5.1...
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I am trying to figure out how to connect my ipod to my Yamaha htr-5930. Can I do that through the headphone jack, or through the aux jack? Is there anyway I can do this? Thanks! nickrd83@gmail.com is where...
Use a 3.5 mm to 2Male RCA cable. Plug this into an AUX or CD input in the back. Adjust the volume on the iPod as well as the master volume to balance out the sound. The headphone on the receiver is output only.
Apr 12, 2011 | Yamaha HTR-5930 Receiver
How do i connect my HDTV to my YAMAHA HTR-5930 receiver? for example i am watching a movie from my usb port on my LG 42LE5300 or i am playing on my xbox, how do i get that sound to come out of the...
The simplest for the movie would be to connect the Optical digital audio out of the TV (above the VGA port) to the Optical Audio In on the receiver. You will need to get this cable from any store that sells TOSLink cables. The manual for the TV is available here: http://www.lg.com/uk/tv-audio-video/televisions/LG-led-tv-42LE5300.jsp . The manual for the receiver is available at the Yamaha support page if you are a registered Yamaha customer: http://download.yamaha.com/search/product/?category_id1=16445&&category_id2=16446&product_id=1060939 .
For the XBox, I'd suggest the same connection if you are using HDMI out on the XBox. If you are using component or composite video, route the audio cables to the receiver's RCA audio in.
I hope this helps.
Feb 22, 2011 | Yamaha HTR-5930 Receiver
I have a Yamaha HTR-5930 Home Theater Sys. Somehow, I've managed to lose my right channel when watching T.V. (dish network), but when my son plays with the XBox, he gets full surround stereo. Any ideas?
The XBox is probably hooked up separately to the amplifier, try cycling the inputs on the amplifier. If that doesn't work replace the cbale between your amplifier and tv.
Nov 19, 2010 | Yamaha HTR-5930 Receiver
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Jun 30, 2008 | Yamaha HTR-5930 Receiver
HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Feb 17, 2008 | Yamaha HTR-5930 Receiver
Yamaha HTR-5930 Receiver Logo
37 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
