Question about Williams Encore Digital Piano
Yamaha cp33 has no volume when key is pressed
    Genius:
  • 1,212 Answers
One key? or all keys?
if one key- the switch contacts for that one key are where to look for dirt, corrosion or broken wires.
If one octave- check wires and connections on the borad that set of wires lead to, and look for bad solder joints or bulging capacitors, or evidence of a spilled beverage.
If all keys, Check to make sure the mute button is not pressed. and volume level is up, and see if headphones will work with it. If you are using headphones- try a different pair first, you may have a broken wire in the headphones Then check the wiring inside, especially the wire for common buss connection. Also check the amplifier for funtionality. This is simply done by pressing a screwdriver in contact with the amplifier input, you should hear a buzz out of the speakers of the keyboard or through the headphones. The amplifier borad is the one with wires to the headphone jack and speakers.
Posted on Oct 28, 2012
Sunken key
You will need to take it into a service center. Here is the Yamaha UK service link-
Contact Us Support Yamaha UK and Ireland
Mar 04, 2016 | Music
Hi. I have a PSR i425 and the auto accompaniment function is not working on it. The screen shows that the function is on. but its not working.. Can you help?
I cannot find a service manual but maybe worth trying the following:
Volume for auto accompaniment is turned down or muted
Try turning the instrument on whilst holding down the top / highest white key - this will initiate a factory reset.
If problem persists contact your local Yamaha service centre.
Jan 19, 2015 | Music
My yamaha keyboard wont make a noise when i press on the keys. the volume is up and everything but it still wont make a noise :( but i dont want to send it out to be repaired please help me.
This may sould dumb, but did you check the Headphone jack? If the 1/4" adapter for 1/8" may be left in the port, like on my keyboard. I took it out and sound came on. Lame, I know, but . . . .
Mar 10, 2013 | Yamaha Full-Size Keyboard
Yamaha CP33 Studio Piano won' turn on. Was thinking maybe the power chord overheated but really have no idea
Make sure you have the CORRECT adapter for the unit. It should say Yamaha on it and match the voltage and polarity. Thest the output with a meter. Common problems that happen to the piano itself causing the symptoms is a broken power connector or broken solder at the connector. Use a meter and verify the adapter is producing output. Expect the output to be a bot higher than listed when not plugged into the piano as there is no load on the adapter.
Apr 29, 2011 | Yamaha CP33 Digital Stage Piano (Warehouse...
Volume difference in keys
Note that the volume of piano keys depends on the "key velocity" which is the speed that the key is depressed. This velocity is MEASURED by the time between closures of the two contacts associated with each key in this unit.
If some contacts have become dirty, then the volume of those keys will vary.
Clean the circuit board traces AND the conductive rubber "pills" using Q tips and ONLY 99% isoprophyl alcohol.
This involves dis-assembly of the unit and you may want to seek professional help with this if you are not electronically adept.
Jun 16, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Mar 10, 2010 | Yamaha Music
Yamaha clavinova CLP200 the amp has lost power
I might suspect that the volume control itself may have a break in the resistance element by your description. There can be many causes however including LOOSE CABLES. IF the unit has been moved recently, then a loose cable MIGHT be the cause. In any case, servicing iis required. If you are not familiar with electronic repair you will need to find an experienced repairman.
Nov 08, 2009 | Yamaha Music
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Williams Encore Digital Piano Logo
159 people viewed this question
Top Williams Music Experts
Robert Graf
Ted Maxwell
rhodesworks
Are you a Williams Music Expert? Answer questions, earn points and help others
