Question about Dell Dimension 3000 PC Desktop
After thermal event, pc will not reboot.
Turns on and says turned off due to thermal event press Enter to continue...Then restart in Windos Normally or "repair mode". However, it never make it through to reboot. just shuts off again. I can hear the fans going non-stop.
  • Dell Master
  • 2,072 Answers
Buy some arctic silver from radio shack ($10). Remove the heat sink from the CPU. Apply a dime sized drop and spread it with a credit card or saving card. Attach heat sink.
Posted on Nov 18, 2013
  • 37 Answers
SOURCE: Fan Malfunction??
Sounds like a heat issue, pop the side of your case open and turn on the PC, are there fans not moving? Take a close look at your processor fan if there is one.
Posted on Jul 10, 2008
  • 37 Answers
SOURCE: Dell Dimension B110 PC Desktop
Double post?
http://www.fixya.com/support/t765871-fan_malfunction
fossilruins
  • 114 Answers
SOURCE: keyboard failure on rebooting
reseat the keyboard connector to the pc or try another keyboard
Posted on Dec 16, 2008
sodeep
  • 3267 Answers
SOURCE: Dell OptiPlex GX260 PC Desktop keeps switching its self on !!!!!!
Check the pwer settings on Desktop-properties-screen saver- power options and set it from there. Disable Hibernation......sodeep
Posted on Mar 22, 2009
cowboytech
  • 69 Answers
SOURCE: pc sht down stating thermal error. suppose processr fan not working. can this be the cause of the eror?
Most of the time you'll never hear the CPU fan. If you don't hear the normal fan sounds coming from your computer, it is most likely the power supply cooling fan. Hold you hand at the back of the computer where the power chord plugs in, while the computer is running, and test if you feel air blowing on your hand. If you don't, then replace your power supply. Make sure, when checking for a new PS that you get the correct pin count. Best to order from Dell since proprietary systems usually use proprietary parts and a generic PS won't fit in the opening at the back of the computer (alignment of the plug and the fan with the opening, etc.)
Posted on May 25, 2009
HI I have a D865 PERL m/b. The CPU overheated, due to a load of dust blocking the heatsink fins. I have cleaned it all up and the heatsink should be fine now, but when I try and boot I get a message...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 14, 2011 | Intel D865PERL Motherboard
I have a black screen that says safe mode, safe mode with networkin , safe mode with command prompt and laast known good configuration but when i go to safe mode my computer just reboot all over again
This recycling/rebooting into this screen is normally caused an error (hardware or software).
You MUST turn off - Automatic Restart to see the error message.
Power down your laptop.
Press the power button to turn-on laptop.
Start pressing the F8 key immediately AFTER the DELL logo screen and BEFORE the windows screen.
You SHOULD be brought to the same screen as you described above but with an additional option: TURN-OFF automatic restart. Select this option and press ENTER.
Let laptop cycle and you should see blue background screen with white letters giving you information.
Please provide the ERROR message on screen BEFORE we can advise you any further.
Mar 30, 2011 | Dell Latitude D600 Notebook
Respected Sir, When I was working on my computer, suddenly the CPU has been put off. I put on it again. It says that my pc had shut down due to thermal event (over heating). When I...
just place your computer in a well ventilated area. if possible add new fans for your pc.. if it is a laptop add an external fan...
akuma_Ryu21
dont forget to rate!
Jan 23, 2011 | Computers & Internet
Problem rebooting Dell PowerEdge Server 2600
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Feb 19, 2010 | Dell PowerEdge 2650 Server
Black screen with curser
It is what is called the "Black Screen of Death (BlSod)/(KSOD)" if you are using Vista or the later Windows 7. There are many causes for the BiSod/KSOD... some may say it is due to Micro**** updates and patches or as what Micro**** claims that is is due to malware infection, most likely something from the Daonol family of Trojans.
Google for it or I'll share you this site to give you some insights of the BiSod/KSOD.
here's one of many you could read:
http://www.pcworld.com/businesscenter/article/183502/three_tips_to_avoid_the_windows_black_screen_of_death.html
For a fix you may follow these steps:
After the black screen with cursor appears, press the shift key several times (5 to 10 times). A window should appear that reads “Go to the Ease of Access Center to disable the keyboard shortcut.” Click on that item, then follow these instructions:
  1. In the explorer window that appears, clear the address entry and type MSCONFIG then press enter. Run MSCONFIG.
  2. Uncheck the two items in selective startup and press apply, then restart the computer.
  3. The computer should start normally. Now click the Start button and type MSCONFIG again, then press enter. Uncheck Windows Event Log and Windows Event Collector, then restart the system.
This may or may not work on your state but your last resort is to extract your hard drive and back-up to another unit before re-installing your OS.
Hope this helps. Don't forget to rate.
Jan 06, 2010 | Sony VAIO PCG-K35 Notebook
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Dell inspiron 6400 rebooting
it is an issue with your software which is not able to find the os in hard drive please perform a operating system reinstall
  1. Ensure all of the Windows XP installation discs and information are present.
  2. Install the Windows XP disc.
  3. Press and hold <Ctrl>+<Alt>+<Del> at the same time to restart the computer.
  4. When the computer restarts and the Dell splash screen appears, press <F12>.
  5. In the Boot menu, use the <Up> and <Down> arrows to select either CD or DVD, and then press <Enter> to continue.
  6. If prompted, press any key to continue. If you do not press a key, the computer starts from the hard drive. In that case, wait until Windows has completed started up, and then begin again.
  7. At the Windows XP setup window, select To set up Windows XP now, press Enter, and then press <Enter>.
  8. Press <F8> to accept the terms and conditions specified in the license agreement.
    new_note.jpg Note: By default, unpartitioned space is highlighted. If any other partitions appear that were not previously created by you, they may include a PC Restore partition or a Media Direct partition.
  9. In the Windows Setup Partition screen, press <Enter> to partition the hard drive. On this screen, review the listed partitions. Usually, the original operating system partition is labeled (OS) and is also the largest partition.
  10. Use the <Up> and <Down> arrows on your keyboard to highlight the OS partition and press <D> to delete the partition.
  11. When the Confirmation screen appears, review the warnings and press <Enter>to continue. You will now be returned to the previous screen.
  12. Use the <Up> and <Down> arrows to highlight the unpartitioned space and press <Enter> to set up Windows XP. The Windows XP Setup appears with the following information highlighted: Format the partition using the NTFS system.
  13. Press <Enter> to continue. On the next screen, a progress bar shows the format process. When the format is complete, the setup files are copied to the hard drive.
    The following message appears: Please wait while setup copies files to the Windows installation folders. This might take several minutes.
    Then follows Setup is copying files…. The status bar displays the percentage complete. When complete, the computer reboots and the set up wizard appears.
  14. When the Regional and Language Options window appears, change as needed, then click Next.
  15. When the Personalize Your Software window appears, enter a name and organization if wanted, then click Next.
  16. When the Product Key window appears, enter the product key, then click Next.
  17. When the Computer Name and Administrator Password window appears, enter a password if wanted, then click Next.
    When you enter the password, be sure the caps lock is off; passwords are case sensitive.
  18. When the Date and Time Setting window appears, change as needed, then click Next.Windows is installed, a progress bar indicates approximately how much of the task is complete.
  19. The computer reboots.
    The Windows XP operating system is fully installed.
Aug 14, 2008 | Dell Inspiron 6400 Notebook
Fan Malfunction??
Jul 10, 2008 | Dell Dimension B110 PC Desktop
Dell Dimension 3000 PC Desktop Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
