Question about Logitech EasyCall Desktop Retail Keyboard, Mouse
I put the USB plug in the two plug housings and the control immage on the screen still says "plug it in". It looks to me that my PC does not recognize my logitech web cam as it did in the past.
  • Frank
    Frank May 11, 2010
    did you install the logitechs' web cam driver ?
    President:
  • 8,637 Answers
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 28, 2009
Situation of plug from door switch to motor control penal
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 24, 2014 | Hotpoint WMA66 Front Load Washer
Ps3 controller charging failed
ok, either your charger for the ps3 is broken...or,it cant read(know)the cord is there. you may have dust or something clogged up. i know cause it happend to my ps2...i blew into the slot where the controller goes ( although u need to blow into the charger where u plug it in. if it doesent work... then u may need to either try a different usb plug or controller and see how it goes...OR take the controller and charger to a friends house if they have a ps3 and see if it works on theirs..if it vworks on theirs...then the thing where u plug the charger in at on the ps3 is probably broken or clogged up with dust
...if it doesent work on theirs than your usb plugs are brokn...
Jun 25, 2012 | Sony BD Remote Control for Playstation 3
Where do i inset the cable from pc
That depends on the make and model of the printer, every printer is different. However, generally speaking if it's a USB printer (as almost every modern home printer is these days) The USB port is normally found at the back of the printer.
However, the usb cable from pc to printer isn't the same at both ends (as you might expect). It's a USB (A) that plugs into the computer and a USB(B) cable that goes into the printer: netean.jpg
Look on Google images for USB B for more examples. In the above image (courtesy of Lindy.co.uk) the plug on the right goes into the printer.
Feb 28, 2011 | Office Equipment & Supplies
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Memory card of nokia 5730 does not show immages in
simply go to nokia housed or customer care around u and get ur self a good memory card then be careful of virus,b4 u put the memory card scan ur phone to make sure is virus free
Apr 07, 2010 | Nokia 5730 Xpress Music Mobile Phone -...
CHANGE HARD DISK
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
I use a cheap 2.5" USB 2.0 case that has the correct connection ie. SATA or IDE. Connect your laptop drive to that. Then connect to a regular PC that has enough space to hold an "immage" copy of your hard drive
I would normally take out the old drive and make an image of it using Acronis or an older version of norton ghost.
I would then put the image onto the new drive and then place the new drive in the laptop. if done correctly your laptop and windows wont even know it was changed.
Once I am sure the new drive is OK i format tho old one put it in the external case and hey presto you have some more storage that you can move between computers.
Oct 05, 2009 | Sony VAIO VGN-FS550 Notebook
What do you use to charge the tom tom 910 in the house
In the box you have a 'desktop' mount. Looks like the windscreen mount without the ******.
Also you will have got a mains power lead.
Plug the lead into the 'desktop mount' (Left hand side) of the stick up bit.
Plug in and put your 910 onto the mount. It will 'Click' into place
The green light will shine to show it's charging.
To release the unit from the mount PRESS in the button in the middle of the screen top rim and lift off.
Remember to turn of the power at the socket to stop wasting electricity
The usb part of the desktop mount goes into your pc so you can connect to TomTom home or just plain old 'back it up'
It is ok to have power switched on or off when connect to the pc, there is no need to unplug the jackplug.
Hope this helps
Feb 28, 2009 | Tomtom GO 910 GPS Receiver
Screen went dim. very faint immage still in in good light. i bought a screen on ebay, the seller said it worked, i hooked it up, it does not work same as my old screen. Could the problem be the inverter?...
it might be the inverter but with out knowing if it is a flat screen or a reguler monitor i will not be able to tell you . you might have to take it to a computer place near you but for now my suggestion is to plug your old one back in for now intell you get the other on looked at
thanks
hope this works for you
Aug 19, 2008 | Computers & Internet
ACER
The screen cable has come loose just needs pushed back in look up how to take the case apart (the screen and above the keyboard is usually all you need) locate the cable and push it in all the way if it is a plug then usnplug it and plug it back in on both ends. Put it back together enough to power it up and see if it worked.
May 21, 2008 | Computers & Internet
Logitech EasyCall Desktop Retail Keyboard, Mouse  Logo
99 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
