Question about Toshiba MD20FP3 Combo
Toshiba MD20FP3 radomly turns off
The TV will stay on anywhere from 30 seconds to hours and then randomly turns off. I even brought the TV to a friends house to make sure the electronics at my house causing the problem. Please help. Thanks
  • Kaydedo Apr 18, 2008
    I have two of these TVs, and both of them are doing the same thing.  I turn them off and then they turn off on their own after 15 20 seconds.  They are only 2 years old.  Funny that they both are doing the same thing at the same time.  Seems like a problem with the product.
  • fishface22 Oct 09, 2008
    my turns on then immediately off. How did you repair the connection on the motherboard?
I also have the toshiba tv dvd combo md20fp3 problem. Can someone let me know if the soldering solution worked?
Thanks
Posted on Feb 02, 2008
  • 45 Answers
A loose contact on the mainboard, if you know how to solder then have patience in soldering what you can see in the mainboard that may be having loose contact.
Posted on May 15, 2007
Prima Cineplus 50" Plasma PH-50R18C will not turn on
The ambient temperature might be high. Check whether the foolinf fans are working or not. If not, check out the reason for it. The TV must be placed at least 6cm away from wall, and should have sufficant ventilaation.
Nov 15, 2013 | Televison & Video
Toshiba 46G310U randomly turns off then back on
Finally figured out the issue with this. It's a momentary dip in voltage caused by the A/C, dryer or fridge coming on.
I can reproduce this everytime by turning everything on, then starting the clothes dryer.
Jan 14, 2013 | Toshiba 46G310U LCD TV
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Feb 16, 2009 | Zenith Z52SZ80 TV
Accessing TV Menu withough original remote
No you need the remote ! and even most universals will not do that function for you either!
You can order an orignal replacment remote from www.remotes.com and that will let you access all of the tvs functions!
I hope I was of big help!
Please rate my FREE response!
Thank You!
Jan 17, 2009 | Toshiba MD20FP3 Combo
TV goes off while watching it. Model TRX 3079WHX-Xac
First thing I would do is go back to the dude that charged you $239.oo for a non repair and have him make good! Then see what happens. It, obviously, was not the transformer and his diagnosis was incorrect. Not right for you to pay for his mistake. U paid good money for a repair and all you got was the set back with a different transformer and same issue.
Mar 12, 2017 | Samsung DynaFlat TX-P3076WH 30" TV
Hitachi 50DX10B Power issue
Rollo, broken solder connections either in low voltage or sweep section of the board, probably in the horizontal out put area but could be anywhere. If you want to attempt the fix the board has to come out and you`ll need a bright light as well as a good magnifying glass to find the broken joints and then re-solder them, Be certain your tv`s AC cord is removed from the wall outlet before doing any soldering, good luck, BMW Rider
Dec 13, 2007 | Hitachi 50DX20B 50" Rear Projection...
Toshiba MD20FP3 not turning on
Is a good thing the main fuse is not open,your problem is in the power supply ,as I understand you have no indication of power(no lights,No clicks)The 5 volts that power the microprocessor might be missing,this 5 volts usually come from a regulator,this regulator should have 12 volts in one side and the 5 volts in the other,the 12 volts come from the secondary of a transformer and it has its own fusible resistor,if the resistor is open is because the regulator is shorted and it need to be replaced.This is a good place to check.Be careful when checking this parts.If you are not too familiar with tv service seek the assistance of a servicer,it should not be too expensive.
Oct 03, 2006 | Toshiba MD20FP3 Combo
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Toshiba MD20FP3 Combo Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
