Question about Quasar SP-3220 32" TV
My quasar # sp3220v tv video input dont work
I have a quasar t # sp3220v when i plug in a dvd player in video one rca plugs i dont get soind or video
5 Suggested Answers
  • 126 Answers
SOURCE: what channel to use for my dvd
all depends how u have it hooked up if going thru your rf tuner pobally channel 3 if pluged into video
you will need to be on video that is the yellow for video red and white your sound
Posted on May 03, 2009
SOURCE: my universal remote can't program my quasar tv
please , what model of remote do you have?
Posted on Sep 16, 2009
  • 8457 Answers
SOURCE: my unviersal remote wont work
No,all universal remotes have it limited and difference troubles in each of tvs it uses.Try website like Remotes.com to buy an original remote.
Posted on Feb 14, 2011
  • 214 Answers
SOURCE: quasar tv # sp3220v video/sound input dont work
Are you sure it is on the correct channel or on input, AUX? I would check your manual and see what channel it goes on. If it's on the right channel the connectors on the tv may be broken or the dvd player is broken.
Posted on Oct 30, 2012
Quasar tv # sp3220v video/sound input dont work
Oct 27, 2012 | Quasar Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
What cord do i need to watch a video from my Quasar Palmcorder on my tv. I don't have a vcr anymore, the model is VM-L450.
hi; if you have a audio video out[rca type cable that
you can use it will be fine you plug it in a/v input on your tv theres no need of a vcr exept if you want to record what you have on the camera or you can use
a dvd burner to save it on a dvd disc...
hope that will help you..
Mar 03, 2010 | Quasar VM-D51 Camcorder
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Hi I am trying to connect my sd box via my video player or so it works any where, I dont know where the plugs should go, been trying for two hours. I know it works as my partner had it going earler, but...
I fixed this myself, I pluged the av cord directly from the sd box into the video input, the scart into the tv dvd, the rca into the video from the sd box then from the video rca to the tv rca, works a treat
Nov 16, 2008 | Televison & Video
Trying to hookup dvd
Steps to hook up DVD player:
1. Plug in DVD player
2. Plug in VIDEO cable to back of DVD player
There are multiple video out cable options: HDMI, VGA, RCA
If you aren't sure, use RCA (red, white, yellow tri-plug cable) and plug yellow into VIDEO OUT port.
3. Plug other end of video cable into TV's VIDEO IN port.
4. Turn on TV to the INPUT channel that corresponds with the input port you plugged the video cable into. Usually, this is either VIDEO1, VIDEO2, INPUT1, INPUT2, or channel 3.
May 03, 2008 | Televison & Video
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Rca pro854
you just need to match up the colors of the cables on both the camera and the DVD Player. Also, make sure that you plug the cables into an input on the DVD Player, and that The DVD player is tuned to that input usually accesed before channel 3 or by pressing input on the remote
Jan 10, 2008 | RCA PRO854 8mm Analog Camcorder
Televison & Video Logo
19 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
