Question about Casablanca Fan (3232A) Ceiling
Casablanca Hermosa started working erratically. We replaced the Intelli-touch wall control. Now only the fan works. Instructions sy to replace the
Casablanca Hermosa with light.
5 Suggested Answers
  • 70 Answers
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Posted on Jul 25, 2008
SOURCE: It seems that we need a pc board for our intelli
Thank you, but I already found a web site that sells the conversion kit to update the fan.
I understand that the original parts are no longer made and it is recommended to convert.
Thank you!
Posted on Jul 18, 2009
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Posted on Sep 01, 2010
How do I reassemble a Casablanca Intelli-touch Fan?
get a second ladder and another person to help hold it in place
Aug 08, 2015 | Dryers
How can I change from a remote control system ( which rarely works) to a wall control switch for my isotope 44 from casablanca
Casablanca may be able to supply instructions for alternate methods of wiring your fan for direct control vs. remote control.
Jul 28, 2014 | Casablanca Fans 44" Casablanca Isotope...
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
Jan 26, 2010 | Casablanca Fan Advan?Touch W-62 Remote...
It seems that we need a pc board for our intelli touch casablanca fan - where can I find one for out model #AS26069
Thank you!
Jul 17, 2009 | Casablanca Fan 3245T Ceiling
Casablanca ceiling fan lights flicker out
here is solution for you.
instead of put all Fluorescent light bulb, put one incandescent bulb.
Dont' ask why but it works. (use 60w or above)
Mar 15, 2009 | Dryers
Casablanca Fan (3232A) Ceiling Logo
82 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
