Question about Homelite 150 mph 400 CFM Gas Blower UT09521
How to change to vac
Can someone tell me how to change from a blower to a vac?
How can I change from vacuum mode to blower mode?
Don't know what make you have. Maybe post a picture if you're still struggling. Most electric vac/blowers have a leaver or a dial/knob on the side that you turn in order to go from vac to blower, but mort the time you also have to put extra pipework on too as the blower outlet then becomes the vac inlet.
Apr 16, 2016 | Garden
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Oct 05, 2014 | Toro 51592 Super Blower Vac 3-In-1...
My leaf blower doesn't start, I put new gas in it & put new sparkplg but doesn't start. Please help me
you list it as an electric vac if it s gas ans you have changed gas and plug if its older you gase lines could be brittle I had to change them on mine to get it to work
Sep 17, 2010 | Craftsman 225 Mph Electric Blower Vac
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A...
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
I bought a Toro ultra electric blower vac (model 51599 a year ago but never used it. Now that I need to use it I can't find what I did with the instructions. What do I have to do to attach the vacuum bag?
Common sense tells me it is not that hard you probably do not need an instruction manual, does life come with a instruction manual O Yeah the Bible. Believe in yourself review the situation, think it over you can do it!!!!!!!!!
Nov 25, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Blower housing
TRY A COMPANY CALLED GIANT VAC
Sep 22, 2009 | Toro Blowers Rake and Vac - Electric...
Fuel lines dry and brittle how to replace on craftman 24cc gas powered blower vac
take one of the lines to a hardware store and see if they have the proper size. You should be able to change them easily. Just remember to clamp the ends to prevent gas from leaking out.
Jun 15, 2009 | Toro Blowers Rake and Vac - Electric...
How to change spake plug on powerlite snow blower
Remove the two screws holding the control panel to the machine. The spark plug is behind the panel.
Dec 23, 2008 | Toro Blowers Rake and Vac - Electric...
Homelite 150 mph 400 CFM Gas Blower UT09521 Logo
14 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
